Ultimately, it depends on the vehicle. For example, on an Audi A4 (8E), you can see when the next service is theoretically due by looking at the data blocks (data block 221, field 1).
At the end, it depends on the vehicle; for example, with the Audi A4 (8E), you can see, based on the data blocks (data block 221, field 1), when the next service is theoretically due.
This can be done on the 8E using a button on the instrument cluster... however, this will then display the actual value of the interval in kilometers and days.
Well, you can find that in all .
'Values' and 'Service' are always included in the adaptation channels.
4. Describe your problem as vaguely as possible, without making any vehicle- or engine-specific statements. Ignore any suggestions for further tests or questions about the engine or vehicle type, but expect a psychic remote diagnosis.
Just as correct/incorrect is my statement .
