Turbocharger Boost Pressure Explained
randylok
Post01-11-2004, 19:13    Subject: Turbocharger Boost Pressure Explained Quote
Can someone tell me what boost pressure my T-loader should be producing?
'Recently, I've been experiencing a lot of smoke when accelerating, especially above approximately 2500 RPM.'
Translated on 23-10-2026, 20:30.
Gremlin
Post01-11-2004, 19:32    Subject: Turbocharger Boost Pressure Explained Quote
That's a really good question, and I'm also noticing that the database of actual values seems to be incomplete.
I would generally say that anything below 0.9 bar is not good.
Otherwise, check the other possible causes of the error as described in the technical article.
CU Gremlin.
Post02-11-2004, 21:14    Subject: Turbocharger Boost Pressure Explained Quote
Otherwise, check the other possible causes of the error according to the technical article...
Or simply use VAGCOM to log the boost pressure control (including the current target value).
Then, practically, you don't need a table icon_wink.gif.
But, strong smoke when accelerating usually has different causes than low boost pressure -> check the EGR valve to ensure it's completely closing, and check for "vacuum" leaks in the intake manifold between the turbocharger and the engine.
Translated on 23-10-2026, 20:31.
randylok
Post02-11-2004, 22:16    Subject: Turbocharger Boost Pressure Explained Quote
Sorry, but that's where the wisdom ends.
Translated on 23-10-2026, 20:32.
Marco
Post02-11-2004, 23:40    Subject: Turbocharger Boost Pressure Explained Quote
Take a look at this: https://community.dieselschrauber.org/en/viewtopic.php?t=3095
christians
Post03-11-2004, 12:54    Subject: Turbocharger Boost Pressure Explained Quote
ulf wrote:
"Suction" pipe leaks between the turbocharger and the engine.
That would be my first suspicion. A visual inspection might also help in this case.
Gruß Christian
Translated on 23-10-2026, 20:33.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Death of My Turbocharger - Toilet? Diesel Engine Technology
No new posts Turbo Whistle Noise When Accelerating Diesel Engine Technology
No new posts VTG Turbocharger Boost Pressure Diesel Engine Technology
No new posts AJM boost pressure On-Board Diagnostics (OBD)
