g1om Guest
08-11-2004, 23:30 Subject: BMW Diesel: Starting Problems with CMR 1u2 |
Hi, I know this isn't really your area of expertise, but I was wondering if maybe someone here could take it on and include it with their BMW/MINI content.
Affected: All BMW diesel vehicles equipped with the CMR 1 and 2 generation systems.
Effect: Increased difficulty starting when the engine is warm.
Error code: Insufficient rail pressure at start-up.
Cause: One or more injectors are defective.
In the diesel engines mentioned above, one or more injectors can cause starting difficulties due to excessive fuel leakage.
Troubleshooting: Check the amount of fuel leakage with the engine running and at idle.
Maximum 180ml in 3 minutes. If a value above this is detected, all injectors must be replaced.
Best regards, G1om.
Translated on 22-08-2026, 6:53.
kalle Guest
09-11-2004, 1:13 Subject: BMW Diesel: Starting Problems with CMR 1u2 |
It is a common CDI error.
It's not just happening with BMW.
However, only the defective injectors need to be replaced. Unless, of course, they are matched sets. It's quite an expensive undertaking.
Translated on 22-08-2026, 6:55.
