ESP 1Z: Key Settings & Configuration
macgyver68
Post09-11-2004, 22:38    Subject: ESP 1Z: Key Settings & Configuration Quote
Can someone give me the ESP setting value for the 1Z (Audi 80)? icon_question.gif
Is a dial gauge sufficient?
What is the oil pressure actually?
THANK YOU
Regards, manu.
Translated on 02-11-2026, 19:00.
joergs
Post10-11-2004, 8:02    Subject: ESP 1Z: Key Settings & Configuration Quote
To adjust the initial timing, a timing light is sufficient. In theory, in 95% of cases, the engine will then start. At the very least, it should start with this setting. The adjustment value (if I remember correctly) is 0.7 +/- 0.02. HOWEVER: There are risks and side effects, so be sure to read the 'megakaltstartthread' by haehlein!
In my opinion, the timing advance should only be adjusted dynamically (i.e., using a VAG-COM or an original VAG tester) for it to be meaningful and reasonable.
Translated on 02-11-2026, 19:01.
