Kommunikationsprob mit KI trotz angepasstem CHAR INT Wert | Posts 16+
Go to page: Previous  1, 2
Post06-11-2004, 17:29    Subject: Quote
You can't really get involved in the individual operating system installation process... Professional adapters certainly have their purpose icon_wink.gif.
Translated on 30-07-2026, 23:11.
Uwe@Ross-Tech
Post07-11-2004, 0:06    Subject: Quote
I'm a bit desperate because we have this AI system on the test bank, and it even works with simple interfaces. icon_smile.gif But you shouldn't argue based on success.
-Uwe-
Translated on 30-07-2026, 23:12.
wolle
Post07-11-2004, 12:02    Subject: Quote
Hi Uwe,
I am absolutely convinced that it will work even with "simple" interfaces. Your AI being put to the test is the best proof of that.
What could be the reason that it's not working on my car...? icon_question.gif icon_question.gif icon_question.gif
For example, who says that the problem is solely due to AI?
(Which specific version of Windows are you using?)
However, so far there appears to be no established "patent solution" or a guide for narrowing down the problem or resolving it.
I would like to test this further, but I don't have a second defective AI device with the same order number, and I'm not going to keep this "dumb" interface.
Well... I wish you all a lovely Sunday and thank you again very much for your support!!!
Translated on 30-07-2026, 23:13.
Uwe@Ross-Tech
Post09-11-2004, 4:47    Subject: Quote
Unfortunately, I don't know why it's not working with your car that has a 'simple' interface.
I have tested the AI on our test bench with several computers and Windows versions. P-100 with NT4, P-133 with W95, up to a dual 2.4 GHz Xeon with XP. Possibly, the problem lies in the firmware version of the AI. I believe that the problems stem from the fact that the AI does not have a real UART, but uses a software-based UART, and that the bits being sent are occasionally extended. Even when you connect a VAG-1552 and use a protocol analyzer to see what happens, you can see many errors and repetitions. So, honestly, I'm glad it works at all.icon_smile.gif
-Uwe-
Translated on 30-07-2026, 23:15.
wolle
Post10-11-2004, 10:22    Subject: Quote
@Uwe...
You're welcome.
If that's the case, I'm just going to be happy for you... hihi icon_twisted.gif.
Wool.
Translated on 30-07-2026, 23:16.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts LMM Value Too High? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts AHF Tdi. Value of the initial injection start? On-Board Diagnostics (OBD)
No new posts LMM Replacement: When to Change (mg/h) On-Board Diagnostics (OBD)
No new posts Start of AEL funding - Early value maximization? Diesel Engine Technology
