Climate-Friendly ASZ: Agile Solutions!
Post13-11-2004, 0:16    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Today I noticed that my car's air conditioning system accelerates much faster when set to "Auto" compared to when it's in "Eco" mode. There's a noticeable difference of several seconds (roughly measured) between 120 km/h and 180 km/h.
How is that possible? Shouldn't it be the other way around?
The instantaneous peak power consumption values from the MFA are identical, so they aren't very useful for a rough estimate of the injection quantity.
Translated on 29-07-2026, 1:56.
Post13-11-2004, 10:10    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Roger wrote:
I noticed today that my car's air conditioning system, when set to "Auto" on the Climatronic, accelerates much faster than when it's in "Econ" mode. There's a difference of several seconds (roughly measured) between 120 km/h and 180 km/h.
The peak power consumption values from the MFA are identical, so they are not very useful for a rough estimate of the injection quantity...
Well, then you'll have to delve deeper and log the fuel injection amount.
Perhaps the climate control software is designed in such a way that it deactivates the compressor (for a longer period) when set to "Auto" mode and during full-throttle acceleration?
Translated on 29-07-2026, 1:58.
Post13-11-2004, 20:57    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Hello Ulf,
Well, in "Econ" mode, the compressor should ideally remain off for a much longer period icon_smile.gif.
I'm thinking more along the lines of coolant temperature, which would be lowered by the immediately starting cooling fan. Is there a kind of "soft" emergency mode that activates when the coolant temperature is too high – but still below the warning threshold – where no error code is stored, but the performance is reduced?
Logging will resume no earlier than next weekend.
Translated on 29-07-2026, 2:00.
Post14-11-2004, 0:11    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Okay Roger, go ahead.
Unfortunately, I couldn't detect any differences with ASZ ERF, both with and without the air conditioning on. I'm not sure to what extent the coolant temperature should be considered. The assumption that a "higher" performance curve is used when the air conditioning is turned on to compensate for power consumption hasn't been definitively disproven. If the climate control is set to "Auto" and the compressor shuts off at full load, as it does in my case, it's possible that this higher performance curve remains active, which could potentially explain the increased power output.
As I said, this is speculative.
Translated on 29-07-2026, 2:01.
Post14-11-2004, 0:16    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
It also reacts much more spontaneously even at partial load, and it doesn't require full load to achieve this.
Translated on 29-07-2026, 2:02.
Julian
Post14-11-2004, 11:57    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
I'm thinking more along the lines of coolant temperature, which would be lowered by the immediately starting cooling fan. Is there a kind of 'soft' emergency mode that activates when the coolant temperature is too high – but still below the warning threshold – where no error code is stored, but the performance is reduced?
Hm, mal geloggt, was die beiden Kühllüfter an Strom ziehen? Die geringe Mehr-Kühlluft frisst der höhere Strombedarf des Generators wieder auf. MinSure.
Do you still have a magnetic clutch on your AC compressor, or have you already switched to the one with a wobble plate?
The warning threshold for the Golf 4 TDI, to my knowledge, is >110°C; before that point, the engine control unit (ECU) does nothing, and only mechanical/thermodynamic values play a role. icon_smile.gif
Translated on 29-07-2026, 2:03.
andre
Post15-11-2004, 14:51    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Could it be that the engine receives different mapping parameters when the air conditioning is activated?
Translated on 29-07-2026, 2:04.
Fireball
Post17-11-2004, 16:47    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
Other parameters are likely not affected, but the fuel injection quantity is probably slightly increased.
/viewtopic.php?t=5748&highlight=poor
Post26-11-2004, 12:35    Subject: Climate-Friendly ASZ: Agile Solutions! Quote
@ulfViewing profile: ulf:
I've been monitoring the shutdown condition of the air conditioning compressor on channel 19 for a few days because the outdoor temperatures were close to the threshold for low-temperature shutoff.
There were two interesting effects observed:
- The compressor runs even at an outside temperature of only +2 degrees Celsius for more than 20 minutes and only shuts off when the temperature permanently reaches icon_smile_thumb_up.gif.5 degrees (shutdown condition 14, "Function of evaporator temperature"). At a traffic light, it even restarts at icon_smile_thumb_up.gif.5 degrees (shutdown condition 0).
- The control unit (CT) briefly deactivates the compressor during rapid acceleration with more than approximately half throttle (deactivation condition 12, "Engine Control Interface").
At approximately icon_smile_thumb_up.gif,5 degrees Celsius ambient temperature, a situation can even arise where the compressor is switched off during constant speed driving, then switches back on at the next traffic light, and is subsequently switched off by the Motronic system when starting, only to be switched off again immediately due to low temperature (14 -> 0 -> 12 -> 14).
There must be a wobble plate in the compressor, because all of this happens smoothly without any noticeable jolts. Without the display, it wouldn't even be noticeable.
I think a magnetic coupling wouldn't be able to handle this control scheme for very long either.
Unfortunately, I haven't been able to log anything yet, but the more agile behavior described at the beginning hasn't changed regarding how the car operates.
Translated on 29-07-2026, 2:07.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate defect Transmission, Chassis, Body & Interior
No new posts Climate Control A4 Malfunction? Transmission, Chassis, Body & Interior
No new posts Prima Klima Transmission, Chassis, Body & Interior
No new posts 1.9 TD Diava with Climate Control Transmission, Chassis, Body & Interior
