Julian wrote: |
@Ulf:
Are you sure that everything is okay with the power supply of your 9Ns? I don't think 13V is high for such low-power devices; perhaps your line regulator is faulty? |
Here's another update after a few measurements.
In the µCarge thread, I described how I measured the resistance of my B+ line using the 5A power supply.
Computationally, this resulted in a line resistance of approximately 1.6 mΩ (including a 175A fuse with 0.4 mΩ), which is roughly plausible for a 1-meter length of 16mm² copper cable.
I just measured the voltage drop in the wiring after the engine start, while the voltage is still rising towards 14V, meaning that the alternator, under full load, is primarily supplying power to the glow plugs and the battery's charging demand.
There were measurements of up to 110 mV, which, even at 840 motor rpm, suggests a current output of the alternator of around 70 A
(nominal current = 90 A).
Gremlin's hypothesis that the screw fuse might exhibit increased resistance under load (due to potential contact problems or heating) has not been confirmed: A voltage of 25 mV across the fuse corresponds quite accurately to its share of approximately 25% of the total cold resistance.
Even a rough calculation of the acceptable load until the onboard voltage drops with a warm engine (LL = 840 rpm) doesn't reveal anything fundamentally different:
-> Rear window defroster = 17 A (just measured).
-> Heater fan at full power = 16A.
-> Total current consumption for low beam, high beam, and parking light: approximately 19 A.
-> Pre-charge pump = 4 A
-> Power steering with pump in the left-hand side = approximately 2 A.
They have been together for 58 years.
In addition, there's the difficult-to-estimate power consumption of the engine (PDE, solenoid valves, TCU), as well as minor consumers like the instrument cluster, ABS, and likely some current draw for charging the battery, which probably never fully charges given my mostly short trips.
The result is trending towards 70A, which my small 90A LiMa already achieves in reduced idle speed -> Respect
If I then have the brake (6 A) and NSL (2 A) activated, as well as the prohibited NSW (8 A), the battery would definitely be discharged in the LL (low-level) mode, so the load manager would urgently need to increase the speed - even without afterglow or active electric heating.
It's good
and also entertaining to have a voltmeter on board so that I can additionally monitor the whole thing.
