ABS Error Troubleshooting: Find the Cause (Solution)
Post06-12-2004, 15:04    Subject: ABS Error Troubleshooting: Find the Cause Quote
If you are currently experiencing seemingly inexplicable ABS errors, specifically with the ABS warning light illuminating after starting the vehicle, you should carefully inspect the fuses of the ABS hydraulic unit. This fuse, typically rated at 30A, can oxidize due to its exposed location in the engine compartment, creating resistance. While a simple voltage measurement during troubleshooting will show the full value, under load during the pump's self-test, this resistance becomes significant, and the hydraulic unit is then reported as defective.
Depending on the vehicle, these fuses are either screw-type fuses or plug-in fuses and are housed in separate enclosures in the engine compartment or above the vehicle's battery.
Translated on 18-09-2026, 8:31.
Ratings - ABS Error Troubleshooting: Find the Cause
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts A6 2.5 TDI: 1000+ Common Problems & Fixes Diesel Engine Technology
No new posts Faulty Door Control Units: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Error 01039 and 18047: Relationship and Causes On-Board Diagnostics (OBD)
