VW Passat TDI: Combination Instrument Board Repair
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Autofitti
Post22-12-2004, 11:50    Subject: VW Passat TDI: Combination Instrument Board Repair Quote
"Regarding the vehicle from May 2000 with an AFB engine and automatic all-wheel drive, the MFA (Multi Function Display) shows a brake error message, and the ABS light is illuminated in the instrument cluster. When reading the fault memory, an error related to the combination instrument circuit board is displayed. Is it possible that there's a bad solder joint or a faulty connector, or is replacement of the entire unit the only solution?"
Translated on 21-08-2026, 2:28.
gwg
Post22-12-2004, 11:55    Subject: VW Passat TDI: Combination Instrument Board Repair Quote
Hello Autofitti,
We'll probably only be able to say for sure after it has been removed and visually inspected.
Perhaps it's just a connection problem with a plug.
Günther.
Translated on 21-08-2026, 2:29.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
No new posts T4 Syncro 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Off-Road Suspension for VW Golf 3 Syncro Transmission, Chassis, Body & Interior
No new posts VW Passat 1.9 TDI 1Z 5 errors, including G70, G81, G62 Diesel Engine Technology
