Boost surge (06-12-2004, 20:41)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post06-12-2004, 20:41    Subject: Boost surge Quote
Hi!
I have another question about the results of a measurement run. I used VAG-Com to do a very detailed analysis on my colleague's Bora, and I noticed that the boost pressure was slightly negative. Now, I would like to ask you experts for your opinion. Specifically, this AHL Bora always exhibits overboost with maximum values of up to 2.5 bar icon_eek.gif. Since it hasn't been chip-tuned or anything else, and it's a 90 hp engine, that seems a bit too much to me.
Here's the translation:
"What is particularly striking is also the extremely aggressively acting charge pressure limiting valve (see graphic - blue line). Since the AHL [presumably referring to a specific system or component] doesn't have a VTG either, I think the valve itself is more likely the cause. Or am I mistaken icon_question.gif"
By the way, the graph looks the same in several measurement runs. So, the 2.5 bar reading wasn't just a one-time anomaly...
http://img131.exs.cx/img131/1327/Ladedruck.jpg
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Translated on 16-07-2026, 18:22.
Back to top Profile PM Email
Post06-12-2004, 21:12    Subject: Re: Boost surge Quote
wbuchi82 wrote:
Specifically, the AHL Bora experiences overboost situations with pressure surges reaching a maximum of 2.5 bar icon_eek.gif. Since it hasn't been chip-tuned or modified in any way and is a 90 horsepower engine, this seems like too much to me.
Well, pressures up to approximately 2.2 bar (absolute!) are considered normal.
The extremely aggressively designed wastegate valve (see graphic - blue line) is also particularly noticeable. Since the AHL doesn't have a VTG either, I think the valve itself is more likely to be the cause. Or am I wrong icon_question.gif
Yes, you are seeing something wrong:
1. Does the ALH have a VTG loader?
2. Is the "aggressively reactive" behavior of the valve simply a reaction to excessive pressure?
The graph looks the same in several measurement runs. Therefore, the 2.5 bar is not a one-time anomaly.
I suspect the variable geometry turbocharger (VGT) or the solenoid valve is stuck... or (less likely) the VGT rod is incorrectly adjusted and too short.
Translated on 16-07-2026, 18:24.
wbuchi82
Post06-12-2004, 21:27    Subject: Boost surge Quote
icon_redface.gif ....tja, ist natürlich der ALH gemeint ....... bei dem vielen Varianten komm ich ab und zu durcheinander.... icon_lol.gif
The ALH actually already has VTG icon_question.gif. Then I made another mistake...
I thought the 90 horsepower engines didn't have a VTG system yet – only the PD engines did... but believing doesn't mean knowing icon_lol.gif, and I haven't gotten under the hood to check.
Then I should probably do that and check the VTG (Variable Turbine Geometry), or possibly replace the valve as a test.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Translated on 16-07-2026, 18:27.
DocSnydor
Post08-12-2004, 23:02    Subject: Boost surge Quote
After installing my LDA (Lambda-Probing Device), I also noticed that my Golf's overboost pressure sometimes reaches up to 1.5 bar. However, this only happens occasionally; otherwise, the overboost pressure maxes out at around 1.2 bar. I haven't bothered to check how easily the VTG (Variable Turbine Geometry) adjustment moves yet... unfortunately, that requires getting under the car again.
Translated on 16-07-2026, 18:28.
Gremlin
Post08-12-2004, 23:32    Subject: Boost surge Quote
The ALH actually already has VTG icon_question.gif .
yepp... the rumor persists stubbornly, even among those who are directly in front of it and see it happening icon_wink.gif.
'Mine has been doing that kind of over-expansion (1.2 bar) from the beginning.'
CU Gremlin.
Translated on 16-07-2026, 18:29.
dieseldevil
Post27-12-2004, 13:08    Subject: Boost surge Quote
Overshoots can also occur even when the maximum LD value in the dataset has not been increased.
That's how you damage the battery in stop-and-go traffic with the constant overcharging... icon_wink.gif
Translated on 16-07-2026, 18:30.
No new posts Ladedrucküberschwinger On-Board Diagnostics (OBD)
No new posts 2.5 TDI BDG: Boost Surge Explained On-Board Diagnostics (OBD)
No new posts Boost overrun V6 TDI BDG Upload
No new posts 1.9 TDI BLS Ladedrucküberschwinger Diesel Engine Technology
