Turbocharger Types: A Complete Guide
caddy
Post18-08-2002, 15:28    Subject: Turbocharger Types: A Complete Guide Quote
Weiß jemand eine Quelle aus der ersichtlich ist welcher Motor mit welchem Turbolader ausgerüstet ist? Besonders interessiert mich der AFN und der 85kW PD. Vom 85 kW PD weiß ich relativ sicher das der einen Garrett 18 drauf hatte (richtig?). WaWhat does 's' mean when referring to the number 18?
Best regards, caddy.
Translated on 26-10-2026, 7:48.
Post18-08-2002, 20:19    Subject: Types of Chargers: A Complete Guide Quote
Hi.
The AFN likely (and quite certainly) has the VNT 15. I don't know exactly what those numbers mean.
Mtw13ve
Post23-08-2002, 12:39    Subject: Turbocharger Types: A Complete Guide Quote
It has something to do with the turbine size and all that stuff... as far as I know.
All 90, 110, and 115 horsepower models: VNT-15. All 130 horsepower models: VNT-17. And the 150 horsepower model: VNT-20.
You can check it out on www.egarret.com...
'cu' is a Spanish abbreviation for 'con usted,' which means 'with you.' It is often used in online communication to indicate that the sender is available to chat or talk.
Here is an example of how 'cu' might be used in a conversation:
Person A: 'Hey, I'm bored. Want to chat?'
Person B: 'Cu!'
This means that Person B is available to chat with Person A.
'Cu' can also be used to indicate that the sender is thinking about the recipient. For example, if Person A sends a message to Person B and then receives a reply that says 'cu,' it could mean that Person B is thinking about Person A and wants to connect with them.
Overall, 'cu' is a versatile abbreviation that can be used in a variety of ways. It is a common way to indicate availability, interest, or affection in online communication.
Translated on 26-10-2026, 7:50.
TDII
Post02-09-2002, 9:58    Subject: Types of Chargers: A Complete Guide Quote
It should be noted that VNT 15 (for AFN engines) is a Volkswagen designation, and this is actually a VNT 17 from Garrett icon_exclaim.gif.
Best regards, Holger.
Translated on 26-10-2026, 7:51.
Uwe
Post02-09-2002, 12:31    Subject: Turbocharger Types: A Complete Guide Quote
Hi!
www.egarrett.com
Uwe.
Mtw13ve
Post02-09-2002, 21:20    Subject: Turbocharger Types: A Complete Guide Quote
'They are called GT 17 VNT-15 and -17, and that's because, except for the outlet, they are essentially the same model. The only difference is that the turbine itself is slightly larger in the VNT-17 model. Those are the facts I'm getting from the US.'
Person B: 'Cu!'
Translated on 26-10-2026, 7:52.
A4Tommy
Post04-09-2002, 15:41    Subject: Turbocharger Types: A Complete Guide Quote
greetings!
So, in the AFN engine, the same turbocharger (VNT-15) is used as in the 130hp PD engine?
What kind of chargers can be used as a 'replacement' there?
It sounds like they all look the same on the outside, but just have slightly different turbines inside!
cu, thomas
Translated on 26-10-2026, 7:53.
