StevieB Guest
07-08-2002, 9:04 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hello everyone.
'For the past few days, I've been experiencing a problem where the engine loses power when accelerating to around 130 km/h. It seems to go into some kind of emergency mode and shuts off the turbo! If I stay below 130 km/h, it runs normally. If I turn off the ignition and restart the engine, the error is reset, and it runs normally again. I've already replaced the mass airflow sensor, but it didn't solve the problem. Best regards, Stefan.'
Translated on 26-08-2026, 10:57.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
07-08-2002, 9:09 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
As always in these cases: Have the error codes read out and, if necessary, have a diagnostic test run (see also the error database or other posts). Please post the results here.
What is the model year and engine code? Tschüss
Michael II
Translated on 26-08-2026, 10:58.
StevieB Guest
07-08-2002, 11:16 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hi.
It's an AJM engine, manufactured in July 1999, with a mileage of 60,000 kilometers.
The engine hasn't been tuned. The only modification I've made so far is installing an auxiliary radiator.
Stefan
ttns4 Guest
12-08-2002, 16:06 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
I drive a Passat PD 115 AJM.
If the problem 'randomly' appeared after the GRA (presumably a performance upgrade) was installed, I would next time check if it's still possible to get some acceleration from the GRA. Perhaps the control unit is receiving two different signals?!
(Just an idea.)
Good luck.
Thorsten
Translated on 26-08-2026, 10:59.
StevieB Guest
12-08-2002, 16:26 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hello.
The error has not occurred for a few days, but the error memory was still read.
17958 - Turbocharger boost pressure regulation differential.
08-10 - Limit exceeded - Intermittent.
and deleted.
Stefan
Translated on 26-08-2026, 11:00.
holgerweb Guest
13-08-2002, 16:24 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hello Stefan,
I've been experiencing the same problem intermittently for about a year. Every time, the error memory was completely empty. The workshop couldn't find anything. I wrote a letter to VW's complaints department so that I would still have warranty coverage if the problem is ever found.
While driving at full speed, the engine power suddenly drops to a maximum of 100-130 km/h. After restarting the engine, everything is fine for about 3 months. I have experienced this 4 times already.
If you find out anything, let me know.
Holger.
Translated on 26-08-2026, 11:01.
StevieB Guest
14-08-2002, 16:10 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hello.
I got excited too soon - the error is back  .
However, it seems there is a correlation with the outside temperature.
'This happens more often in warm weather. I replaced the coolant temperature sensor a few weeks ago because it was causing errors in the error memory.'
I can borrow a laptop with diagnostic software over the weekend. Can anyone tell me which parameter blocks/addresses I need to read out (boost pressure, MAF sensor signal, etc.) to narrow down the problem?
Stefan
Translated on 26-08-2026, 11:02.
Franz Guest
18-08-2002, 22:30 Subject: Solenoid Valve: Types, Applications & Working |
Hello Stefan,
'I had the same problem with my Passat TDI 90PS. It annoyed me for a long time. Thanks to the people here in the forum, I was able to fix the problem. In my case, the turbocharger boost control valve was defective. Now everything is okay again. It costs about 30 euros to replace, and it's worth it.'
Best regards, Franz.
Translated on 26-08-2026, 11:04.
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
18-08-2002, 22:44 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
StevieB wrote: | ...can someone tell me which measurement blocks/addresses need to be read out (boost pressure, mass airflow sensor signal...) in order to narrow down the error?
Best regards, Stefan |
Hello Stefan,
Check the error database and search for your engine code!
Translated on 26-08-2026, 11:05.
Profile PM WWW Garage |
StevieB Guest
05-09-2002, 9:48 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
Hello.
I've now had a brand new MAF sensor for about 2 weeks, and the car has power again. The first MAF sensor I replaced was a 'slightly' used one that worked perfectly in another car (also an AJM) that it was taken from  .
Interestingly, since then, it has only once gone into emergency mode during a longer highway drive. Could it be that the VTG (Variable Turbine Geometry) system, for example, 'jams' after a longer drive at a constant speed, causing the TCU (Transmission Control Unit) to switch to emergency mode? I have already checked the VTG linkage for proper movement, and I was also able to finely adjust the valve using a syringe and vacuum.
Stefan.
Translated on 26-08-2026, 11:06.
cesys Blaumann
Joined: 06/24/2002 Posts: 44 Karma: +5 / -0 Location: Saarland
05-09-2002, 17:41 Subject: TDI Performance Issues: 1.9 TDI PD 85kW |
I'm having a similar problem! Please take a look at what's happening on my end.
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Translated on 26-08-2026, 11:07.
