Hi.
The next one in line is the next turbocharger
I had to take my (1Z) outside because the exhaust manifold gasket was leaking – so I removed the entire exhaust manifold/turbocharger assembly and left it disassembled.
Now, the turbo needs to be replaced on the JX (T3 TD).
- Should I remove the intake manifold including the turbo and disassemble it on the workbench?
Can I reuse the (very expensive) screws that connect the turbocharger to the exhaust manifold?
- Can I use a regular socket wrench on these screws, or is specialized tooling required? (Background: I once read that a regular socket might fit.)
Is there anything I can do to prepare the turbocharger before installation that wouldn't be possible after it's installed? (Filling it with oil for lubrication is obvious).
"Thank you."
