Will einen AJM Motor im Golf 4 reparieren und bräuchte Tipps | Posts 16+
Go to page: Previous  1, 2
JA´s Car Service
Post24-01-2005, 18:12    Subject: Quote
Hello.
'No, I didn't take offense to what he wrote!'
The crack extends from the combustion chamber, through a cooling channel in the cylinder head, downwards into the crankcase and into the first groove. I believe the mixture took the easiest path downwards into the crankcase, and the engine didn't run for long after the fault occurred. That's probably why there are no traces on the cylinder liner...
I don't have a tester for VW vehicles yet. I'm seriously considering getting one, but it's quite an expensive investment.
P.S.: MatthiasTdi96, do you have a repair manual for the engine?
Translated on 26-09-2026, 3:02.
Post24-01-2005, 19:29    Subject: Quote
"Do I own something like that? What's it to you?"
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Tips and tricks for care and crafting Technical Articles
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Golf IV TDI: Can Engine Control Unit Be Repaired? On-Board Diagnostics (OBD)
No new posts ZR-W replacement for V6 TDI engines, or "How to destroy a... Diesel Engine Technology
No new posts Install VW Golf 3 TDI 1.9L Engine Diesel Engine Technology
No new posts Rim Width for VW Golf 4: What Fits? Transmission, Chassis, Body & Interior
