Sporadic engine failure 1Z
turbo
Post24-01-2005, 19:30    Subject: Sporadic engine failure 1Z Quote
Hello TDI enthusiast community,
I have the following problem:
"In my Golf III TDI (engine code: 1Z, manufactured in August 1994, 372,000 km), the engine occasionally stalls while driving. However, in most cases, it can be restarted without any problems after a short period of time." Reading the error memory (even when there are no errors) and replacing the known relay 109 have not been able to solve my problem so far.
Perhaps some of you have already experienced this problem with your vehicle.
I would be grateful for any advice.
Jörg.
Post24-01-2005, 19:48    Subject: Re: Intermittent engine failure 1Z Quote
turbo wrote:
In my Golf III TDI (engine code: 1Z, manufactured in 8/94, 372000 km), the engine occasionally stalls while driving.
However, in most cases, it can be restarted without any problems after a short period of standstill. Reading the error memory (even when there are no errors) and replacing the known relay 109 have not been able to solve my problem so far.
Bitte gib den Text an, den du übersetzt haben möchtest.
I am grateful for any tip.
Occasionally, older vehicles may exhibit instability around the 109 component, which can cause effects similar to those of a faulty relay.
I would start by connecting a temporary indicator LED to the output of the 109 and observing whether it continues to light up after the motor shuts off, or not.
Subsequently, the further search will be guided by this.
golf3schrauber
Post25-01-2005, 13:51    Subject: Sporadic engine failure 1Z Quote
For me, it was a faulty DWA (wireless door communication system). The problem was caused by cold solder joints on the relays. After soldering it, everything was quiet.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
No new posts sporadischer Leistungsverlust A4 TDI 110 PS, AFN On-Board Diagnostics (OBD)
No new posts Sporadic performance loss with Log On-Board Diagnostics (OBD)
No new posts TDI: Intermittent Power Loss - Troubleshooting Diesel Engine Technology
No new posts A6 Avant TDI BJ.95 sporadischer Leistungsverlust 192.000 km Diesel Engine Technology
