Tiptronic: Soft Coding Without Value?
PeterK
Post01-02-2005, 9:16    Subject: Tiptronic: Soft Coding Without Value? Quote
Hi there,
I have a Tiptronic GKB FST manufactured in September 2001. When using VAG-COM, no value is displayed for the soft coding. Is this normal? Can VAG-COM not read this, or is there an error?
"By the way: Can anyone confirm the engine control unit coding for an ATD with an FST Tiptronic transmission?"
Here's the translation:
"Also, what's the probability of the mileage being incorrect if the shop's instrument panel displays '00000' but the rest of the text indicates '02000'?"
Peter K.
Address 01 -------------------------------------------------------
Controller: 038 906 019 FF
Component: 1.9L R4 EDC G010AG 1449
Coding: 00001
Shop #: WSC 01317
WVWZZZ1JZ2W252xxx VWZ7Z0A4156586
No fault code found.
Address 02 -------------------------------------------------------
Controller: 09A 927 750 N
Component: AG5 Transmission 09A 0163
Address 17 -------------------------------------------------------
Controller: 1J0 920 846 C
Component: KOMBI+WEGFAHRSP VDO V02 (This appears to be a product code or identifier.)
Coding: 17114
Shop #: WSC 00000
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
aab 78ps und 4 betten, küche, aussendusche
133+ Tkm
Translated on 19-10-2026, 12:10.
Uwe@Ross-Tech
Post01-02-2005, 15:59    Subject: Tiptronic: Soft Coding Without Value? Quote
Which version of VAG-COM did you use?
-Uwe-
Translated on 19-10-2026, 12:12.
PeterK
Post01-02-2005, 16:26    Subject: Tiptronic: Soft Coding Without Value? Quote
the old 3.11xy version.
I found something online using Google that suggests there are options like that available (a Tiptronic without coding).
Peter K
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 19-10-2026, 12:13.
Theresias
Post01-02-2005, 18:59    Subject: Tiptronic: Soft coding without value? Quote
by the way: can anyone confirm the engine control unit coding for an ATD with an FST Tiptronic transmission?
Component: 1.9L R4 EDC G010AG, 1449.
Coding: 00001
Shop #: WSC 01317
The coding is fine because the Tiptronic transmission has no influence on the coding process during the ATD (Automatic Transmission Diagnosis) procedure.
See: http://de.openobd.org/vw/golf_1j.htm#01
Translated on 19-10-2026, 12:14.
PeterK
Post01-02-2005, 20:40    Subject: Tiptronic: Soft Coding Without Value? Quote
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 19-10-2026, 12:15.
Theresias
Post01-02-2005, 22:50    Subject: Tiptronic: Soft Coding Without Value? Quote
Okay, the first thing that comes to mind is to test a new software version.
311.x is already considered 'out of date'.
Just come by and take a look; everything is available in its current version. Then you should be able to find the error.
Besides, I'm still looking for a way to test some label files live. icon_wink.gif
Translated on 19-10-2026, 12:16.
PeterK
Post06-02-2005, 20:49    Subject: Tiptronic: Soft Coding Without Value? Quote
Good evening.
We could consider that at some point..., right now the car is going back for another repair under the warranty, let's see if it helps...
Peter K.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tiptronic A6: Gap Between Gears - Problem? On-Board Diagnostics (OBD)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts 2,0 TDI ohne Leistung Diesel Engine Technology
No new posts AXR Log: 150 Ohm vs. No Tuning Upload
