Label Files: How to Create & Use Them
uk
Post24-02-2005, 19:34    Subject: Label Files: How to Create & Use Them Quote
Is it correct to have as many label files as possible in a folder? And does it matter whether you include German files in an English VGA version, or vice versa? Will they still work?
Greetings and thank you.
Translated on 13-10-2026, 3:14.
Post24-02-2005, 19:43    Subject: Label Files: How to Create & Use Them Quote
Maybe.
You can do it intelligently, like for example on http://openobd.org (Download Area), or unintelligently.
It's considered intelligent when a) the label files are correct, and b) the wildcards provided by VAg-COM for different control unit variants are used. This allows a single file to cover multiple control units.
It's unintelligent to save the file multiple times with different names using Ctrl+C and Ctrl+V for each variation.
Translated on 13-10-2026, 3:15.
Theresias
Post24-02-2005, 21:23    Subject: Label Files: How to Create & Use Them Quote
...is it correct to have as many label files as possible in the folder, and does it matter whether you insert German files into an English VGA version or vice versa? Will they still work?
For stress-free operation, with current VAG-COM versions (409.x and higher), it is recommended to save new label files in the 'VAG-COM/labels/user/' subfolder, as this folder is searched first.
It's unintelligent to use Ctrl+C and Ctrl+V for each variation and save the file x times under different names.
That reminds me of someone... *g*
Translated on 13-10-2026, 3:16.
uk
Post25-02-2005, 13:52    Subject: Label Files: How to Create & Use Them Quote
Thank you very much in the meantime.
Is there a more recent German demo version available that works with optocouplers? I still have version 0.81.
Greetings.
Translated on 13-10-2026, 3:17.
Post25-02-2005, 15:56    Subject: Label Files: How to Create & Use Them Quote
I have no interest in providing support for such outdated technology.
You can find a current demo of the product, along with the kit, in our shop.
http://shop.dieselschrauber.de/product_info.php/cPath/21/products_id/38
Just a reminder: version 0.81, which is quite old, might not be compatible with current label files.
Translated on 13-10-2026, 3:18.
No new posts Label Files: Definition & Examples Diesel Engine Technology
No new posts VAG-COM Label Files: Download & Information Diesel Engine Technology
No new posts Label File: Definition and Usage On-Board Diagnostics (OBD)
No new posts Label-Files for VAG-COM / FB to ZV On-Board Diagnostics (OBD)
