Brake Light Switch Failure: Causes and Fixes
Ferdi
Post25-02-2005, 22:49    Subject: Brake Light Switch Failure: Causes and Fixes Quote
Hello fellow DIY enthusiasts!
I would like to share a brief report about a defect in the brake light switch in a Golf 4 TDI manufactured in October 1998.
The friendly person said they would break down frequently, but that it happened again within 2 months, which made me suspicious.
Okay, first, I disconnected the wiring for the aftermarket trailer hitch and pulled the connectors from the taillights. I measured for a short circuit at the brake light switch connector. After connecting the trailer hitch wiring and plugging the connectors back into the taillights, I measured a current draw of 3.7A, which seems okay. Now I've discovered that the third brake light (the LED bar) isn't working. I opened the tailgate, and the fuse for the brake light circuit blew (the brake light switch connector had been temporarily bridged for testing).
Now, I can highly recommend that everyone, in the event of a defect in the brake light circuit, checks the left cable conduit from the interior to the tailgate, specifically the rubber grommet. In my Golf 4, which was only 6 years old, almost all the insulation at the bend was broken! icon_eek.gif
The wiring to the LEDs was completely broken, and I don't want to know what could have happened through those exposed wires! icon_evil.gif
The wires were first re-soldered, then insulated with heat-shrink tubing and additionally wrapped with electrical tape. If it breaks again at the solder joint, a new wiring harness will be installed for 65 euros!
Best regards, Ferdi.
 Heckklappe Golf 4, Kabeldurchfuehrung
 File size:  241.21 KB
 Viewed:  11316 times
Translated on 29-09-2026, 20:53.
LZ
Post25-02-2005, 23:40    Subject: Brake Light Switch Failure: Causes and Fixes Quote
"I'm familiar with that too; those are the areas with inherent weaknesses. I usually use LAPP cables there. I have some leftover pieces from a previous project. They're super flexible and have fine strands. However, even they have their limits at sub-zero temperatures. There are no affordable cables that are approved for moving applications and temperatures below minus 5°C."
I would strongly advise against working on the wiring harness when the ambient temperature is below plus 5°C. The insulation can become brittle, and that's when corrosion (green deposits) can start to form.
Best regards, Robert.
Translated on 29-09-2026, 20:55.
No new posts Faulty brake light switch F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error light, indication of defective lamps General Tips
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Light Switch On-Board Diagnostics (OBD)
No new posts Brake light switch, AFB engine Diesel Engine Technology
No new posts Brake Light Switch Wiring Diagram AFN vs 1Z Diesel Engine Technology
No new posts Brake Light Switch & Trunk Release - DIY Repair Electrical Systems, Vehicle Electronics, Multimedia
