I will be purchasing a used DRW transmission on Monday for a conversion on my AFN vehicle.
'Are there any known issues that typically arise around 20,000 km that I can check for visually? Also, what can I inspect without having to do any major work on the spot?'
The following parts are also included: two drive shafts, a matching gear stick, a dual-mass flywheel, and a clutch disc.
Are there any specific things I should be aware of?
The search unfortunately didn't yield much information
Thank you for the tips, which I am sure I will receive.
