Timing Belt Replacement: Bolts Too?
Post02-03-2005, 11:03    Subject: Timing Belt Replacement: Bolts Too? Quote
Okay, I've got everything ready for the timing belt replacement, but now I have a "matter of principle" to deal with:
Should I replace the tensioner pulley bolt as well?
I've got it installed there. If it breaks when I turn it, I'm in trouble. But if it stays in place and breaks after 5000 km, I'm also in trouble.
VW says they are always reinventing it.
What torque in Nm should I use when tightening it into the block, if the nut on the semi-automatic roller is tightened to 20 Nm?
It's a 1Z engine with a "large engine code (greater than 278... or something)," so it's similar to the AHU engine - if anyone is interested.
Translated on 26-08-2026, 15:36.
wolfi_b
Post02-03-2005, 11:28    Subject: Timing Belt Replacement: Bolts Too? Quote
Sure, which text would you like me to translate?
[img]/download.php?id=522[/img]
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 26-08-2026, 15:37.
Post02-03-2005, 11:38    Subject: Timing Belt Replacement: Bolts Too? Quote
That's exactly the role.
But the question refers to the bolt that holds them in the engine. icon_smile.gif
Georg-TDI
Post02-03-2005, 11:46    Subject: Timing Belt Replacement: Bolts Too? Quote
Hi Martin,
I would advise you to leave the tensioner pulley bolt alone.
According to my multiple inquiries to VW before the timing belt replacement in 2001, it was not supposed to be replaced and was supposedly not causing any problems.
Do you know anything about wanting to replace the bolt?
I understand that I can't rely on the information from 'Freundliche' (likely a customer service or support source), because I was told by one person that the tension and idler pulleys should only be replaced on the second timing belt change, while another person said otherwise.
Best regards, Georg.
Translated on 26-08-2026, 15:38.
Post02-03-2005, 11:52    Subject: Timing Belt Replacement: Bolts Too? Quote
I told the service master, when I was there about the warranty for the flexible pipe, that I still needed to do the timing belt and that I wanted to try doing it myself (they know that I take everything apart icon_smile.gif).
He then said that they should replace the bolt, because it would be a shame if an engine failed because a 4-euro bolt wasn't replaced and then broke.
I now have the bolt, so I'm free to decide whether to replace it or not - the 4 euros isn't a problem for me.
I am concerned that only considering the two risks (bolt failure during operation versus bolt tearing during removal) against each other is not sufficient.
Translated on 26-08-2026, 15:40.
Georg-TDI
Post02-03-2005, 12:17    Subject: Timing Belt Replacement: Bolts Too? Quote
For me, the risk of breaking a bolt when trying to remove it or damaging the threads in the block is significantly higher.
Why should the bolt break?
If there are no material defects or material fatigue, and you don't overtighten the tensioner, nothing will break.
Therefore, don't simply place the tensioner pulley on the marking; first, check if there is still enough tension reserve (manually turn the crankshaft several rotations). In the worst case, the timing belt might be slightly shorter, and the tensioner pulley is at the end of its adjustment range and may no longer be able to compensate for the dynamics and potentially a slightly warped pulley. In that case, you will really have the problem that a bolt on the tensioner or idler pulley will shear.
Translated on 26-08-2026, 15:41.
LZ
Post02-03-2005, 12:56    Subject: Timing Belt Replacement: Bolts Too? Quote
Hello.
Is this part "N 014 408 3" an M8x62lg?
Removing a broken stud with a stud extractor isn't ideal, but it's not strictly necessary. If you notice that the stud is turning while trying to remove it, that's not a major problem. You can simply file a flat surface, drill a hole in the center, and insert a Helicoil insert. However, I wouldn't rely on that method, as the combination of aluminum and steel always carries a risk. Furthermore, the head is full of cavities (water channels), and there's a chance of something going wrong while drilling.
Best regards, Robert.
Translated on 26-08-2026, 15:43.
MichaC.
Karma: +9 / -0   Thank you, like it!
Post02-03-2005, 13:11    Subject: Timing Belt Replacement: Bolts Too? Quote
I work at a VW-Audi authorized service center, and we never replace this bolt!
So far, I haven't encountered any cases where the bolt has failed. It's probably extremely rare for it to break or shear off!
"Micha"
Translated on 26-08-2026, 15:44.
Post02-03-2005, 14:57    Subject: Timing Belt Replacement: Bolts Too? Quote
Thanks, Micha.
So, I should just leave him in there.
Translated on 26-08-2026, 15:45.
Post02-03-2005, 22:52    Subject: Timing Belt Replacement: Bolts Too? Quote
For the record, here's the bolt I'm referring to:
On the left, the tensioner is attached, and on the right, the motor icon_smile.gif.
 File size:  73.51 KB
 Viewed:  1889 times
Roadagain
Post02-03-2005, 23:20    Subject: Timing Belt Replacement: Bolts Too? Quote
I would make the decision very simply. If the bolt comes out using the lock nut method, then definitely replace it.
If you determine that the object is securely in place, leave it there.
Greetings.
Translated on 26-08-2026, 15:46.
Post02-03-2005, 23:27    Subject: Timing Belt Replacement: Bolts Too? Quote
Haha :/
That's not so simple.
We broke all the "high-strength" screws from Kruemmer that attach to the turbo on every T3 we had.
You just keep tightening, and eventually, something moves... that's the plastic phase before the break icon_sad.gif.
And if I've already tightened the bolt, then it *must* come out.
So, it's either "let them stay inside" or "definitely take them outside."
MichaC.
Post02-03-2005, 23:34    Subject: Timing Belt Replacement: Bolts Too? Quote
Sure, here's the translation:
"Again:"
Let him in! Nothing will happen! (like it's suggestive icon_smile.gif)
"Micha"
Translated on 26-08-2026, 15:47.
Post05-03-2005, 9:51    Subject: Timing Belt Replacement: Bolts Too? Quote
Okay,
ZR is in, I left the bolt alone, and I'm now really sick icon_sad.gif.
The hall was supposedly "heated," but it wasn't as warm as I thought it would be.
Besides this one, there haven't been any major problems.
- The mother was stuck on the camshaft, completely idiotic.
- The upper screw of the lower timing cover fell behind the alternator (and took approximately 30 minutes to retrieve).
- VW gave me the wrong valve cover gasket (so I have to go back and have it replaced).
- Es gibt zwei Markierungen auf der Schwungschiebe 4. Zyl OT und 1. Zyl OT.
However, they can be identified by the camshafts (which should have the first one at the top), and the rulers don't fit.
Overall, I managed to complete the task within the estimated 4 hours.
The injection start time is set to 45/110 (value 2/9 in the default settings) and should be adjusted to the latest possible setting.
Unfortunately, I now have a core body temperature of 38.6 degrees Celsius.
For the next 90,000 km.
Translated on 26-08-2026, 15:49.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Valve cover gasket leak - unfortunately, also on the timi... Diesel Engine Technology
No new posts Intake Manifold Removal: How To & Tips Diesel Engine Technology
No new posts AGR in USA auch problematisch? Diesel Engine Technology
No new posts auch der Nadelhubgeber? Diesel Engine Technology
