Crankshaft Position Sensor AFN Automatic VW Golf 3
qwert1
Karma-Bildequivalent
Karma: +6 / -24   Thank you, like it!
Post06-03-2005, 18:04    Subject: Crankshaft Position Sensor AFN Automatic VW Golf 3 Quote
hello,
I'm looking for the exact "OT" (Over Timing) mark on the automatic transmission of the engine mentioned. There's a long window and a round opening. But where is the mark located? Does anyone have pictures of it?
Best regards and thank you!
Translated on 26-10-2026, 14:27.
Georg-TDI
Post07-03-2005, 15:41    Subject: Crankshaft Position Sensor AFN Automatic Golf 3 Quote
... there's a long, narrow window and a round opening.
You need to look for the marking in the round opening (red circle in the photo)!
Best regards, Georg.
 File size:  136.95 KB
 Viewed:  11523 times
qwert1
Post07-03-2005, 20:30    Subject: Crankshaft Position Sensor AFN Automatic VW Golf 3 Quote
Okay, here's the translation:
"Thanks! Where should the marking on the casing align? There's no marking on the bell."
best regards
Translated on 26-10-2026, 14:28.
Post07-03-2005, 22:25    Subject: Crankshaft Position Sensor AFN Automatic VW Golf 3 Quote
Some automatic transmissions do not have a marking on the bell housing, in which case the "0" printed on the torque converter housing must be visible in the far left of the window.
It sounds like a rough estimate, but it's worked for us before!
qwert1
Post07-03-2005, 22:44    Subject: Crankshaft Position Sensor AFN Automatic VW Golf 3 Quote
Okay, when I'm standing in front of the car, do you mean the edge of the hole should be towards me, or towards the splash guard?
Translated on 26-10-2026, 14:29.
Post08-03-2005, 9:04    Subject: Crankshaft Position Sensor AFN Automatic VW Golf 3 Quote
to you!
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OT marking on a 3BG Passat 1.9TDI AVF with TT5 automatic ... Diesel Engine Technology
No new posts Golf 1 GTD Timing Belt Crankshaft Timing Mark Diesel Engine Technology
No new posts Golf MKB BSE timing belt or timing marks Gasoline Engine Technology
No new posts Golf 4 1.9 TDI Automatic R won't start. Diesel Engine Technology
