Error images for a two-mass crankshaft?
Post17-02-2005, 19:44    Subject: Error images for a two-mass crankshaft? Quote
in this thread
/viewtopic.php?t=8477
Symptoms of a malfunctioning ZMS were described, including a resolution at the end.
Since the ZMS often causes problems, I would like to supplement the "Common Mistakes" article with descriptions of symptoms, where the root cause was identified within the ZMS.
So, anyone who can contribute something additional or confirming based on their own experience, please post here.
Extracted excerpts from the aforementioned document. Thread:
Golf 4, 1.9 TDI PD, Year 2000, 85KW, 114000km
I'm having a problem where the engine runs very unevenly at idle. At speeds around 1200 RPM, the entire dashboard vibrates. Then it goes away again until around 1600 RPM, then it becomes stronger, and from 2000 RPM it goes away. The rough acceleration is present in all speed ranges.
PD - The elements are OK, and the system has been checked. The LMM is new, along with the air filter, diesel filter, and coolant temperature sensor. There are no errors in the memory. As mentioned, this issue only occurs sporadically and only when the engine is warm. I've noticed that this problem doesn't occur when the outside temperature is around 0 degrees.
No chip and no power box. I just drove and, strangely, everything was working perfectly. And the current temperatures are above 5 degrees. It's infuriating!!! As I mentioned, this awful error only occurs sporadically.
Finally, I found a workshop that immediately knew the source of the vibrations. It was the two-mass flywheel. It was already so broken that the two discs had a play of 3mm in the axial direction. It looked quite alarming.
hollari
Post18-02-2005, 14:59    Subject: ?!? Quote
Hello!
Even at the risk of being perceived as unqualified
'Despite this, I still have this question:'
What is a two-mass flywheel?
Does this only apply to the PD-TDI?
hollari
Post19-02-2005, 3:10    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]Das Bildchen von Google hab ich auch schon gefunden.
Allerdings stellt sich bei mir die Frage :
Was soll das bringen ?
Die Kurbelwelle geht doch nach wie vor
durch das Schwungrad 1:1 durch.
Wenn nun die Schwungscheibe geteilt ist,
dann kann die Unruhe doch nur mehr und keinesfalls
weniger werden, egal wie die beiden Teile verbunden sind,
oder ?
Post19-02-2005, 11:34    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
hollari wrote:
Die Kurbelwelle geht doch nach wie vor durch das Schwungrad 1:1 durch.
Falsch: Auf dem Weg vom Motor zum Getriebe fließt die Kraft durch die Feder-Elemente des ZMS.
Das ist zumindest bei meinem Polo so: ich merke es als "Wabbel-Kraftschluß", wenn ich z.B. den Motor bei eingelegtem Gang durch Vor + Zurückschieben auf OT bringen will.
Robbin
Post19-02-2005, 12:37    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]Hallo,
schön dass mal jemand reagiert.Die ganz oben aufgeführten Zeilen stammen von mir. Das Zweimassenschwungrad wurde gewechselt und ich erkenne mein Auto kaum wieder.Reparaturkosten beliefen sich auf 1358.-. Schon ein ganzer batzen Geld.
Ich war sehr froh dass mir einige Leute Hilfe angeboten hatten,doch finde ich es ein wenig schade dass immer wieder auf defekte Düsen hingewiesen wird.Habe darauf hin ,vor dem Schwungradwechsel meine Düsen testen lassen, und glaube fast dass dies unnötig war.Eine Düse wurde getauscht weil sie angeblich gebrochen war.Ist mir unerklärlich wie im eingebauten Zustand der Stößel abreißen kann. Glaube solangsam dass da beim Ausbau was schief gelaufen ist. Diese Reparatur hat mich 800.- gekostet.Wäre bestimmt vermeidbar gewesen wenn man diesen Ratschlag weggelassen hätte.
Nun nochmal zu den Symptomen des defekten ZMS:
Sehr unruhiger Leerlauf im Stand, Motor schüttelt als wenn er nur auf 3 Zylindern laufen würde, besonders schlimm bei 1000-1200U/min und bei ca 1500U/min.Dieser effekt trat komischerweise nicht immer auf, es gab auch Zeiten wo sich der Motor nicht schüttelte sondern recht ruhig lief.Zum schluss kamm noch ein geschepper aus dem Motorraum im Leerlauf dazu und zwar so stark dass man denken konnte der Motor hätte einen extremen Motorschaden.Geräusch ist weniger geworden sowie die Kupplung getreten wurde.Fehlerspeicher war leer!!!!Mein Freundlicher kannte das Phenomen sehr gut.Als ich einen Termin zur Reparatur machte zeigte er mir noch einen Polo ebenfalls Diesel der das gleiche Problem hatte.Anscheinend hat VW mit diesem ZMS doch recht viel Probleme.Dieses ZMS ist auch nur bei Dieseln verbaut jedoch nicht bei allen Motorvarianten.
Hoffe dass ich ein wenig weiter Helfen konnte und wünsche jeden der Probleme mit dem ZMS hat dass er schnelle und die RICHTIGE Hilfe bekommt!!!!!!!!
Robbin
dieter
Karma: +13 / -0   Thank you, like it!
Post24-02-2005, 12:52    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
@Ulf
Bitte korrigiere doch mal den Umbruch , bei mir (Mozilla) ist das alles 2 Bildschirme breit und entsprechend mühsam zu lesen.
Da es ja hier um das Sammeln von Infos geht zitiere ich mich noch mal selber:
ich hatte eine defektes ZMS und habe beim fahren nichts davon gemerkt. Zur Geschichte: ich habe in meinen Bus einen AFN aus einem G3 eingebaut inkl. Original-ZMS. Kurz nach dem Einbau hatte ich irgendwann ganz schreckliche Geräusche aus dem Motorraum. Sehr laut, als wenn große Kugellagerkugeln im Motor umherhüpfen. Motor aus und wieder an - alles ok. Ist auch nicht wieder aufgetreten. Ich hab mir nicht so viele Gedanken gemacht, da die Kupplungsglocke bearbeitet werden mußte um Platz für das ZMS zu machen und ich dachte da war vielleicht doch noch was im Weg. Ich vermute bei diesem Gepolter ist das ZMS gestorben. Damit bin ich danach noch 20000km gefahren, ohne jegliche Probleme. Dann sollten die Getriebe überholt und angepasst werden. Beim Getriebeausbau haben wir dann das defekte ZMS gefunden.
Die Federn waren gebrochen und deren Reste hatten sich bereits außen durchgearbeitet. Das ZMS war in vollausgelenkter Stellung blockiert, so daß es nur noch nach durchflexen der Stege zu demontieren war.
Angeblich soll es eine (fehlerhafte?) Serie gegeben haben, die keine Fettfüllung hatten. Meins hatte definitiv keine Fettfüllung. Der Motor ist von Anfang 97.
Ich habe jetzt ein ZMS vom Sharan drin und seit 50000km keine Probleme.
Auf eine Anfrage bei Luk bezüglich der Verwendung (nicht des Schadens) des ZMS im Bus habe ich übrigens nie eine Antwort bekommen.
Nach weiteren 10000km wurde das Getriebe noch mal ausgebaut, das ZMS ist offensichtlich noch ok.
dieter
T3 syncro 16 AFN
Post24-02-2005, 19:10    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
dieter wrote:
@Ulf
Hi Dieter,
ich hoffe, daß Dein Problem nur von dem km-langen Link kommt. Den hab ich gerade umbenannt.
Marzocchi
Post24-02-2005, 23:38    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
Hallo.
Ich hatte auch starke vibrationen an meinem Golf IV ALH. Zwischen 2500 und 3200 u/min. Da wurde von VW und zwei anderen Werkstätten auch aufs ZMS getippt. Nach wechsel auf G60 Kupplung mit starrer schwungmasse stelle sich heraus, dass es NICHT das ZMS war.
Das Tilgergeicht auf dem Getriebe hat bei diesen Drehzahlen extrem vibriert und das Dröhnen und vibrieren im Schalthebel ausgelöst. Die eigentliche ursache also die Vibrationen die das Tilgergewicht (wurde jetzt einfach weggeschnitten) anregen zu schwingen sind immernoch ungeklärt. Hat hier jemand eine Idee ?
Was ich mit dem Beitrag eigentlich sagen wollte: Meiner Meinung nach beeinträchtigt ein Defektes ZMS gerade im unteren Drehzahlbereich so bis 2000 U/min vielleicht 2500 u/min...
Wenn man von fällen hört wo es tatsächlich das ZMS war war (soweit ich bisher gelesen habe) nie der obere drehzahlbereich betroffen.
habe übrigens ein funktionstüchtiges ZMS übrig für den ALH / ASV da ich ja jetzt auf G60 Kupplung/Schwungmasse unterwegs bin....
Golf IV - ALH - Erstzulassung 9/99
dieter
Post25-02-2005, 9:40    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
@ Ulf
Ist ok jetzt, danke.
dieter
T3 syncro 16 AFN
Danilo100
Post27-02-2005, 20:05    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
hatte auch ein defektes ZMS, bei ca. 80000 km hatte ich ab und zu ein Vibrieren im Antriebsstrang. Bei ca 85000 km wurde es immer stärker, speziell, wenn der Motor sein grösstes Drehmoment erzeugt. Ich hatte eigentlich auf defektes Motorlager getippt. Bin dann solange damit gefahren bis ich eines morgens nicht mehr von der Ampel weg kam. Beim Getriebeausbau kam mir, das ZMS fast entgegen.( dank ebay gabs für 50 euronen ein fast neues) Ein Kumpel, der bei VW arbeitet, hatte mir erzählt. dass das ZMS zu 90 % zu der Motorleistung ausgelegt ist, führt man dann noch ein 10 Cent Tuning durch oder verbaut eine Box (so wie ich es habe), dann kann das ZMS sehr schnell zerstört werden. Fahre jetzt immer noch mit der Box, nur habe ich sie fast runter gedreht und beschleunige nicht mehr so aus dem Drehzahlkeller. Fahrzeug: Golf 4 Bj. 2001 Mkb: ALH Gkb: EBJ
Gruss Danilo
Back to top Profile PM Email
sunny
Post01-03-2005, 23:03    Subject: Error images for a two-mass crankshaft? Translating...
@ marzocchi
Meine Frage bei welchem Getriebe hast du es so verbaut , sicherlich 5 Gang , oder ?
Stelle diese Frage weil ich mir ein DRW gehohlt habe und am überlegen bin ob da eventuell die Schwungmasse vom G60 reinpasst icon_cool.gif
Welche Nachteile hast du bis jetzt feststellen können ? Und weißt du ob das schon mal jemand an nem DRW oder Vergleichbarem versucht hat?
Angenehme Vorteile bringt das ganze ja mit, wenn mann allein schon mal den Gewichtsunterschied Einmasse<-> Zweimasse vorstellt icon_biggrin.gif
Noch dazu lässt sich die G60 Scheibe wunderbar (Gewichtserleichtern und feinwuchten icon_razz.gif )
Da Frage eventuell nicht zur Umfrage passt bitte verschieben
mfg
Marzocchi
Post02-03-2005, 1:06    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
Hallo. Ja, ich habe die G60 Kupplung am 5 Gang Getriebe.
IMHO passt sie aber nicht aufs DRW oder andere 6 Gang getriebe.
Die Kupplung vom DRW ist aber ja wesentlich grösser und sollte nicht ganz so schnell aufgeben. (Serie G60 hält auch nur max ca. 300NM auf Dauer) Falls doch gibt es sicher etwas wirlich haltbares (auch organisches) (bis ca 450 NM) von Sachs.
Das Schwungrad vom G60 ist übrigens schwerer als das ZMS vom Golf IV 5 Gang.
Zwar nicht westentlich aber doch ein paar hundert Gramm.
Nattürlich kann man es leicht herunter drehen. Aber bitte nicht zuviel. Das mag der Diesel garnicht gern.
Meiner Meinung nach würde der erreichbare Vorteil beim hochdrehen in keinem Verhältnis zu den Kosten stehen wenn Du eine intakte Kupplung samt Schwungrad passend zum DRW schon hast.
Wenn du den Umbau gemacht hast würde ich mich freuen wenn du dich bei mir melden könntest und mir ein paar Erfahrungswerte usw geben könntest. Hatte den Umbau auch schon in Erwägung gezogen. Warum baust du genau um ?
Nachteile, hm weiß nicht, also die Kupplung rupft in den ersten 2 Gängen manchmal ein wenig ist bisher aber erträglich. Ansonsten habe ich den Eindruck, dass sie deutlich besser packt als die Serien-ALH-Kupplung. Das fehlende ZMS merkt man IMHO schon. Ist alles ein wenig direkter und unkomfortabler. Behindert aber nicht. Verstärkte Vibrationen konnte ich bisher nicht irgendwo fühlbar feststellen.
Post09-03-2005, 14:46    Subject: Error images for a two-mass crankshaft? Translating...
[Translating...]
So, ich habe versucht, die bisherigen Beiträge in
/viewtopic.php?t=3285
(ungefähr in der Mitte) zusammenzufassen.
Fehler bzw. Ergänzungen bitte hier posten.
No new posts Two-mass flywheel?! Diesel Engine Technology
No new posts Defective Dual Mass Flywheel: Symptoms & Repair Diesel Engine Technology
No new posts Two-mass flywheel end of life Transmission, Chassis, Body & Interior
No new posts Verstärkte Kupplung beim AFN mit Zweimassenschwungrad Diesel Engine Technology
