Coolant leak in hoses (Solution)
Post10-03-2005, 15:21    Subject: Coolant leak in hoses Quote
Author: Michael II
Cause:
Damage to the hoses from the inside. Due to internal damage, coolant leaks through the fabric lining of the hose and emerges from the ends of the hose.
Solution:
If a coolant leak is detected at the end of a hose, only the affected hose needs to be replaced. Parts that have been contaminated by the leaking coolant must be cleaned (e.g., the coolant reservoir, etc.). After that, a leak test of the cooling system must definitely be performed.
Please provide the German text you would like me to translate.
Bye.
Michael.
Ratings - Coolant leak in hoses
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A4 8D bis KW 45/1998, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku alle VAG Fahrzeuge MJ 2002, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Leak Golf 5 2.0 BKD Diesel Engine Technology
No new posts Coolant Leak Audi A4 AFN: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Coolant loss in CFFB engines after EGR valve replacement Diesel Engine Technology
No new posts Coolant Leak: Connection to Combustion Chamber? Diesel Engine Technology
