Document MKB AKQ, defective timing belt tensioner (Solution)
Post10-03-2005, 15:23    Subject: Document MKB AKQ, defective timing belt tensioner Quote
Author: Michael II
Cause:
Cracks in the plastic sheathing were caused by occasional deviations in the manufacturing process of the timing belt tensioner.
Solution:
In case of a defect, replace both timing belt tensioner pulleys, the idler pulley, and both timing belts.
Up to engine number AHW 164200 or AKQ 241244.
Parts:
Timing belt Z = 58 036 109 119 P
Timing belt Z = 130 036 109 119 Q
Tension spring 036 109 243 F.
Tension spring 036 109 243 AB.
Deflection roller 036 109 244.
From engine number AHW 164201 or AKQ 241245 onwards.
Parts:
Tension spring 036 109 243 AC.
[Addendum from Skoda Doc]
The error also occurs in AUA and AUB engines (Skoda). The intake manifold pressure sensor may be stored as a fault code in the diagnostic memory. This error is caused by incorrect valve timing.
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
Bye.
Michael.
Translated on 15-07-2026, 19:46.
Ratings - Document MKB AKQ, defective timing belt tensioner
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Benzinmotoren, Kerzenschachtzündspulen defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Chain Tensioner Broken Again? Diesel Engine Technology
No new posts AVF: What's wrong with it? Upload
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts MFA malfunction On-Board Diagnostics (OBD)
