Document 1J up to week 38/2000, ABS control light is on. (Solution)
Post10-03-2005, 15:26    Subject: Document 1J up to week 38/2000, ABS control light is on. Quote
Author: Michael II
ABS-control light is on, rear sensor line is damaged.
Cause:
Undesirable tolerances in the connection of the sensor cable with the mounting bracket in the area of the rear left and right fender. In a worst-case scenario, damage to the sensor cable could occur.
Solution:
Please check the connection between the sensor cable and the mounting brackets for a secure fit. If the sensor cable can be easily loosened from the clamps, then tighten the clamps by at least 1 mm to a maximum of 2 mm.
_________________
Bye.
Michael
Ratings - Document 1J up to week 38/2000, ABS control light is on.
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dashboard airbag warning light illuminated, all MJ 2000 d... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KM Stand Control: Check & Monitor On-Board Diagnostics (OBD)
No new posts Kontrolle Kraftstofftemperatur - wie? On-Board Diagnostics (OBD)
No new posts Airbag control problem On-Board Diagnostics (OBD)
No new posts Controlling the injection timing (AFN) with shareware VAG... On-Board Diagnostics (OBD)
