Engine Misfire: 2.4L & 2.8L Motors (Solution)
Post10-03-2005, 15:30    Subject: Engine Misfire: 2.4L & 2.8L Motors Quote
Author: Michael II.
Engine idling roughly.
Poor compression readings on cylinder bank 2.
Error entry in the engine control unit: Camshaft position sensor, bank 2, not communicating with the crankshaft sensor.
Cause:
Due to tolerances, it is possible for the camshafts to be misaligned relative to each other on cylinder head 2.
Solution:
After repairing the cylinder head (bank 2) and adjusting the camshaft timing, the engine crankshaft must be rotated 720 degrees after reassembly. Then, the timing marks on the gears must be precisely aligned with the marks on the bearing cover.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 21-09-2026, 4:57.
Ratings - Engine Misfire: 2.4L & 2.8L Motors
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rough Idle 2.5 V6 TDI BDG Engine Diesel Engine Technology
No new posts Passat Idle Problem: AVB Engine Fix Diesel Engine Technology
No new posts Ford TDDI - unrunder Leerlauf Diesel Engine Technology
No new posts 1.9 TDI: Intermittent Idle Issues & Fixes On-Board Diagnostics (OBD)
