Document: Gasoline Engines, Audi, Model Year 2001, Combustion Failure (Solution)
Post10-03-2005, 15:31    Subject: Document: Gasoline Engines, Audi, Model Year 2001, Combustion Failure Quote
Author: Michael II
Burn-out retarder on a single cylinder
Cause:
Ignition coil faulty
1. R4 2.0 l and V6 3.0 l - Engine
Ignition module with part number 06C 905 115 D, 06C 905 115 E or 06C 905 115 F
from chassis numbers
4B 3N 015100
8E 3A 142 000
8H 3K 009 000
2. R4 1.8T and V6 2.7T Engines
Ignition module with part number 06B 905 115 J, 06B 905 115 L, 06A 905 115 or 06A 905 115 A from production date 30/2002 onwards for the following chassis numbers
4B 3N 000 115
8E 3A 123 000
8N 31 000 220
8L 3A 026 000
3. R4 2.0 FSI
Ignition module with part number 06D 905 115 A, 06D 905 115 C, 06D 905 115 D, 06F 905 115 or 06F 905 115 A from production week 48/2002 onwards with the following chassis numbers
8E 3A 142 000
8P 4A 002 000
4. All V8 - Otto - Engines
Ignition module with part numbers 077 905 115 C, 07C 905 115 D, 077 905 115 C, 077 905 115 E or 077 905 115 F from 2003 onwards
Solution:
When the ignition coil is faulty, the combustion points are only stored on one cylinder.
Are the misfires stored on multiple cylinders, other causes for the error code entries could be responsible. (e.g. Incorrect air intake, camshaft adjustment, fuel system)
Exhaust gas emissions control systems can have many causes (e.g., (Fuel injector), but not always is the distributor ignition coil responsible for this.
_________________
Bye.
Michael
Ratings - Document: Gasoline Engines, Audi, Model Year 2001, Combustion Failure
No new posts Doku Benzinmotoren, Kerzenschachtzündspulen defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B from 9/2001, window opening sealing faulty Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S4 B8, engine code CAKA, misfire P0303 Gasoline Engine Technology
No new posts TDI A3 8P: Misfire Troubleshooting Guide Diesel Engine Technology
No new posts R5 PD BAC Combustion Interrupter and LLR at Full Capacity Diesel Engine Technology
No new posts VR6 Misfire: AYL, Sharan - Cylinder 1, 3, 5 On-Board Diagnostics (OBD)
