Ladedruck Regeldifferenz | Posts 16+
Go to page: Previous  1, 2
cesys
Avatar-cesys
Post15-07-2002, 14:42    Subject: Quote
@rainerViewing profile: rainer
I inquired with ***, and they said that the target boost pressure is approximately 150-200 millibars higher than in the standard configuration.
Translated on 11-08-2026, 2:11.
Post15-07-2002, 15:28    Subject: Quote
Okay, thanks! That puts your values right at the limit...
cesys
Avatar-cesys
Post15-07-2002, 15:33    Subject: Quote
Would you still suspect a faulty charger or the VTG (vehicle terminal gateway) in that case?
Translated on 11-08-2026, 2:12.
Post15-07-2002, 15:47    Subject: Quote
I would get in the car and check the boost pressure values/air mass values, as well as how the system regulates itself. Ideally, I'd do this with someone who knows what they're looking at.
cesys
Avatar-cesys
Post15-07-2002, 18:56    Subject: Quote
Hmm, I would do the same! But try finding one from VW that has the expertise to handle it.
Just got off the highway, and I'm experiencing power loss again despite having a new mass airflow sensor. Well, it seems more and more likely that the turbo is the problem.
Translated on 11-08-2026, 2:13.
cesys
Avatar-cesys
Post05-09-2002, 16:36    Subject: Quote
Okay, here I am again.
After a long back-and-forth between the dealer, me, and both VW locations in Wolfsburg and *** (the control unit has now been updated with the original software), someone from the factory was there yesterday.
Conclusion: The turbocharger is being replaced now, and I'm curious to see if this drama will ever end...
Translated on 11-08-2026, 2:14.
cesys
Avatar-cesys
Post20-09-2002, 13:37    Subject: Quote
Okay, the turbo has been replaced, and the car is running better than ever!
VW will acquire 100% of the turbocharger, and I'll probably have to pay for part of the installation.
I would also like to mention that the company *** has proven to be a very reliable and competent partner in this matter. (The reversal of the performance enhancement for troubleshooting, as well as the subsequent re-application of the performance enhancement, were carried out free of charge and without any problems).
Jens
Translated on 11-08-2026, 2:15.
Post20-09-2002, 13:59    Subject: Quote
Okay, thanks for the feedback!
No new posts Document A6 4B, Fresh Air Blower Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Boost Pressure Control Difference AHH On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Regulation Difference Upload
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
No new posts TDI AHU; 00575 - Intake manifold pressure regulation diff... On-Board Diagnostics (OBD)
