Vacuum Tube Function: Explained & Uses
reuselkopp
Post17-03-2005, 13:25    Subject: Vacuum Tube Function: Explained & Uses Quote
I'm confused!
I have a G3 variant with an AFN engine, manufactured in August 1997.
"When I look at Ulf's post about the function of vacuum control and compare it to my setup, I don't understand some things. Directly from my vacuum pump, there are hoses going to the EGR valve and the brake booster, which seems okay so far. Then, a hose branches off, one part going to a vacuum reservoir and the other to a small electric valve, whose output then disappears into the injection system towards the engine compartment. What is this valve for? When I look at Ulf's post, I only see a valve for the shut-off flap, but my engine doesn't have something like that."
Greetings.
Reuselkopp.
Translated on 23-08-2026, 21:03.
Post17-03-2005, 13:33    Subject: Vacuum Tube Function: Explained & Uses Quote
Do you have air conditioning?
It is likely that this switch controls the recirculation system.
Furthermore, you forgot to mention the connection to the VTG icon_smile.gif.
Translated on 23-08-2026, 21:05.
reuselkopp
Post17-03-2005, 14:52    Subject: Vacuum Tube Function: Explained & Uses Quote
Hello Dieselmartin,
Yes, my car has air conditioning. Does that hose belong to it?
Oops, I forgot to include the hose for the VTG (Variable Transmission Gear) in the list!
Greetings.
Reuselkopp.
Translated on 23-08-2026, 21:06.
Post17-03-2005, 16:22    Subject: Vacuum Tube Function: Explained & Uses Quote
Just try it out.
Okay, disconnect the hose, engage the starter, and turn the recirculation system on/off.
You shouldn't notice any difference if the recirculation flap is controlled using this type of pressure regulation.
m,
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts Function of the L-line? Diesel Engine Technology
No new posts AGR Function: Basic Settings Mode On-Board Diagnostics (OBD)
No new posts C2 Clutch: Function and Operation Transmission, Chassis, Body & Interior
