ABS abschalten | Posts 16+
Go to page: Previous  1, 2
Jockel
Karma: +15 / -1   Thank you, like it!
Post18-03-2005, 9:37    Subject: Quote
syncro peter wrote:
mealtime
brake light switch?
peter
Enjoy your meal!
Sure, here's the translation:
"e.g., the Teves (or ATE) Mk 4."
I have one at home from a 35i model; it has a wire connected to the brake light switch.
Unfortunately, I cannot say whether the ABS system interprets the action as "brake being applied."
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 18-10-2026, 13:49.
Back to top Profile PM Email
Theresias
Post18-03-2005, 12:01    Subject: Quote
My personal experience so far has been that when a circuit breaker is tripped, an error is logged, either during the tripping process or shortly thereafter. Consequently, there may also be various errors logged in other systems, especially if they are networked.
Now, let's get to the main point: intermittent errors sometimes disappear after a certain amount of time, and this may also apply to these specific errors. In at least one case, the warning light went out again; although errors were still stored, they were only saved for troubleshooting purposes and did not affect the ABS operation.
So, as always: Nothing is mandatory, everything is possible.
Translated on 18-10-2026, 13:50.
syncro peter
Post18-03-2005, 12:08    Subject: Quote
hello
Okay, I've also noticed that it's not a constant error. But now, the crucial question again: Where would be the best place to install a switch, or rather, to insert a switch, to turn off the ABS?
peter
Translated on 18-10-2026, 13:51.
No new posts Disable Seatbelt Alarm: How-to Guide On-Board Diagnostics (OBD)
No new posts Deactivate Cooling Water Glow Plugs Diesel Engine Technology
No new posts VAGCOM: Disable Museum Warning? On-Board Diagnostics (OBD)
No new posts PD-TDI Engine Noise When Shutting Off Diesel Engine Technology
