Airbag Control Unit VW Golf 3
AchimTZR
Post23-03-2005, 20:59    Subject: Airbag Control Unit VW Golf 3 Quote
Here's the translation:
Last November, I had an accident with my Golf. Someone apparently damaged the left side of my car... icon_evil.gif icon_evil.gif
Well, he paid for everything. In the accident, my side airbag deployed.
So far, I haven't purchased any new airbags, but I did buy a control unit for one from E***.
Okay, here's my question: Can I install and connect this new "used" airbag control unit without having the airbag installed? And does the lateral acceleration sensor also need to be replaced?
To my knowledge, airbag deployment is permanently stored in the control unit, which is why it needs to be replaced. Will the error code from a previously deployed airbag also be "permanently" stored in my new control unit?
Thank you in advance for your help.
Achim
Golf III GTi TDi 20 Jahre AFN 81 kW
Translated on 24-08-2026, 23:24.
Theresias
Post23-03-2005, 21:42    Subject: Airbag Control Unit VW Golf 3 Quote
The sensor is likely located within the control unit itself.
It should be sufficient to replace the airbag module along with its initiator.
'Note:'
'On eBay, used engine control units (ECUs) are very commonly sold.'
which have been reset, meaning control units that have already triggered once.
Personally, I wouldn't trust this one, no matter what the seller said.
Translated on 24-08-2026, 23:26.
Post23-03-2005, 21:43    Subject: Airbag Control Unit VW Golf 3 Quote
You can certainly install the new control unit yourself. However, an error will be stored and displayed because the side airbag is not connected. The side airbag sensor must also be replaced. Once you have connected the side airbag (and sensor), the error can be cleared using a diagnostic tool.
If you're still interested in buying the side airbags: I have two front seats with side airbags that I removed and have lying around (I replaced them with Recaros). If you're interested, please send me a private message. Otherwise, they will soon be available on the largest online auction platform.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 24-08-2026, 23:28.
Post24-03-2005, 14:47    Subject: Airbag Control Unit VW Golf 3 Quote
After Theresia's simultaneous response initially caused some temporary uncertainty, I double-checked: Contrary to what Theresia stated, the side impact crash sensor is not included in the control unit (ECU). Therefore, I still recommend replacing it.
Sure.
Translated on 24-08-2026, 23:29.
Theresias
Post24-03-2005, 15:03    Subject: Airbag Control Unit VW Golf 3 Quote
The side impact crash sensor is - contrary to Theresia's statement - not included in the control unit (ECU).
Perhaps my word choice was a bit unclear; it should better say control unit AND ignition coil.
The crash sensor (side airbag) is located in the Volkswagen Golf 3 under the carpet (under the corresponding seat).
Anyway, there are people who are capable of triggering airbag deployments.
which contains a mechanically operating acceleration sensor.
reset it - after that, no one can really guarantee what will happen when things get heated.
Translated on 24-08-2026, 23:30.
rinderwahnsinn
Post25-03-2005, 14:46    Subject: Airbag Control Unit VW Golf 3 Quote
Impact sensors should ALWAYS be replaced, regardless of the principle they operate on!
If a sensor has been accelerated beyond its trigger threshold, it may have sustained mechanical damage. Consequently, reliable operation can no longer be guaranteed!
If the sensor is integrated into the control unit, then the entire unit needs to be replaced!
Sure, here's the translation:
'CU' is an abbreviation for 'see you.' It can be used in a variety of contexts, such as:
* In text messages or emails to say goodbye.
* At the end of a phone call or video chat.
* When leaving a meeting or event.
* As a casual way to say hello when arriving somewhere.
'CU' is often used by people who are close friends or family members, but it can also be used in more formal settings.
Translated on 24-08-2026, 23:32.
AchimTZR
Post28-03-2005, 16:52    Subject: Airbag Control Unit VW Golf 3 Quote
Hi there,
dankeschön für die Antworten. Den Sensor für Querbeschleunigung unterm Sitz hätte ich eh getauscht, denn sonst macht der airbag doch mal nix wenn man ihn braucht. SicShe is definitely safe!
Danek and MFG.
Okay, here's the translation:
"Achim"
Translated on 24-08-2026, 23:33.
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Airbag Control Unit: Guide & How-To On-Board Diagnostics (OBD)
No new posts A3 TDI: Airbag Error 65535 - Troubleshooting On-Board Diagnostics (OBD)
No new posts SRS Airbag Control Unit E220D - W210 On-Board Diagnostics (OBD)
No new posts Airbag Control Unit: Coding Only? On-Board Diagnostics (OBD)
