Ignition switch, Vento? Adapter sleeve?
fricki
Karma: +7 / -3   Thank you, like it!
Post03-04-2005, 18:33    Subject: Ignition switch, Vento? Adapter sleeve? Quote
I wanted to replace the electrical part of the ignition switch today.
I looked at the instructions, but I'm not quite clear about the adapter sleeve that I need to remove.
Where exactly is it?
I've already disassembled everything today... but how can I pull them forward?
I could have just used a puller, but I was too unsure whether it would fit properly.
euwing
Post04-04-2005, 15:04    Subject: Ignition switch, Vento? Adapter sleeve? Quote
I did it the way described in the post.
http://www.schraub-selbst.de/viewtopic.php?t=8761&sid=a199cfe82da92f6dcaeda71a305ba784
It took me a while to realize that using pliers to support the puller would be a good idea...
fricki
Post05-04-2005, 6:05    Subject: Ignition switch, Vento? Adapter sleeve? Quote
I'm familiar with the instructions, thank you.
There used to be a tutorial with pictures online, but I can't find it anymore.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Vento Center Console: Parts & Accessories Transmission, Chassis, Body & Interior
No new posts TDI Upgrade: VW Vento 90 PS to 110 PS Diesel Engine Technology
No new posts Golf 4 Speedometer for VW Vento Diesel Engine Technology
No new posts Webasto Installation: Vento Mounting Guide Transmission, Chassis, Body & Interior
