Ich werde morgen einen Passat TDI Bj. 1995 mit 172000 km probefahren und möchte wissen, worauf man motorentechnisch zusätzlich zu den Tips & Tricks zum Gebrauchtwagenkauf auf dieser Seite noch achten sollte, um nicht die "Katze im Sack" zu kaufen. Bei den alten TD-Motoren konnte man zum Beispiel beim Öffnen des Öleinfüllstutzens bei laufendem Motor an der austretenden Abgasmenge erkennen, wie gut noch Kolbenringe+Kopfdichtung intakt sind......(auch beim TDI)? ViThank you very much.
1. whether it starts easily and without any complaints.
2. whether all the stickers (timing belt change/service booklet/oil change) are present and also the correct ones.
3. whether the performance is adequate (ideally, test drive a similar car that is in good condition beforehand).
4. Yes, and also whether the car is complete, including things like the spare tire, etc.
'Actually, VW cars don't tend to rust very quickly. If one does, I would try to negotiate a lower price.'
6. whether the summer/winter tires are in good condition.
Thank you for the additional tips!! I got the Passat at a relatively good price..................but unfortunately, it has the TDI jerking issue that is frequently discussed in the forum. Well, then you can expect to see some more posts from me here .
Best regards, Christian.
