AJM PUDÜ: 115 HP Engine Not Starting?
Crissi
Post02-10-2002, 7:16    Subject: AJM PUDÜ: 115 HP Engine Not Starting? Quote
'Since my car (with 120,000 km) isn't pulling as well as it used to (I'd say there's a noticeable turbo lag between 2000 and 2200 RPM), I'd like to check the turbocharger. To be honest, I'm not even sure if it has a variable geometry turbocharger.'
Are there any other typical symptoms of poor acceleration besides turbocharger issues and a faulty mass airflow sensor?
Translated on 30-10-2026, 19:46.
Post02-10-2002, 8:49    Subject: AJM PUDÜ: 115 HP Engine Not Pulling? Quote
Crissi wrote:
I would like to check the turbocharger. To my shame, I must admit that I'm not sure whether it has a variable turbocharger???
Hi.
As far as I know, all PD models have a VTG turbocharger.
Are there any other typical symptoms of poor acceleration besides turbocharger and mass airflow sensor issues?
If you mean "causes," then yes, of course.
One thing is the usual filter issues (which tend to become noticeable primarily in the higher frequency range).
and specific PD (partial discharge) problems with the injectors, which occasionally fail.
Besides these major issues, there are also numerous minor problems that can occur (in every car), usually somewhere in the electrical system (e.g., relay 109 - if PD models also have this part. I haven't seen a wiring diagram yet).
Translated on 30-10-2026, 19:48.
Frankie
Post02-10-2002, 8:53    Subject: AJM PUDÜ: My 115HP Engine Runs Again! Quote
Hi Crissi,
"Why don't you disable the EGR (Exhaust Gas Recirculation) system? I actually did that about 1.5 weeks ago. Since I disabled the EGR, the car is running great again!"
You can find instructions on how to do it in the forum, even with pictures!
Frank.
Translated on 30-10-2026, 19:50.
Michael II
Post02-10-2002, 8:53    Subject: AJM PUDÜ: 115 HP Engine Not Starting? Quote
Hello Crissi,
Have you ever had the error memory read out, or have you done a diagnostic test drive?
Tschüss
Michael II
Translated on 30-10-2026, 19:51.
Crissi
Post02-10-2002, 9:49    Subject: AJM PUDÜ: 115 HP Engine Not Starting? Quote
Hello Crissi,
First of all, thank you to everyone for the tips and suggestions!
I haven't read the error codes yet, unfortunately, I don't have a service tool.
But... a manual for the Sharan, with license plate codes ANU and AUY, I think they are identical to the AJM. I need to borrow the 1552 or 1551 model sometime this weekend.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts A3 1.9 TDI not pulling properly Diesel Engine Technology
No new posts A6/AEL: Why No Speed Above 3000 RPM? Diesel Engine Technology
No new posts A6 2.5 AEL: No More Proper Pull-Through:-(( Diesel Engine Technology
No new posts Diesel Prices Soar, Impacting Food Costs Diesel Engine Technology
