Read TDI error codes yourself...
T3Tobi
Karma: +0 / -1   Thank you, like it!
Post19-05-2005, 10:20    Subject: Read TDI error codes yourself... Quote
Hello everyone,
I recently installed a 1Z engine in my VW bus. Now I want to read the error codes, because for some inexplicable reason, there's no control signal reaching the fuel shut-off valve.
I've already identified all the cables from the tree (gray/white, +, -).
Now the question is, how can I read the data myself? A friend suggested that I need to build a "small" circuit and solder a connector to it to connect it to my PC. Does anyone know anything more specific about that?
Sure, I'd be happy to help!
Greetings from Freiburg.
Tobi.
wolfi_b
Post19-05-2005, 10:33    Subject: Read TDI error codes yourself... Quote
Use the search function.
There is a technical article that deals specifically with that topic.
In addition, the homeowner sells diagnostic adapters [url][/url].http://shop.dieselschrauber.de/{MARKER}
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Golf 2: Read Error Codes with VAG-COM On-Board Diagnostics (OBD)
No new posts Read fault codes, location Duisburg, Audi A6 V6 TDI, year... On-Board Diagnostics (OBD)
No new posts DIY VAG Connector: Build Your Own! Diesel Engine Technology
No new posts Adjusting suspension geometry yourself? Transmission, Chassis, Body & Interior
