Heated Mirrors: A New Approach!
frank.witten
Post06-05-2005, 14:36    Subject: Heated Mirrors: A New Approach! Quote
I'm having a different problem with my driver's side exterior mirror.
It's heating up now, even when it's turned off!!!
Has anyone else experienced something like this?
The passenger-side mirror functions normally and can also be turned off.
Audi A4.
1.9 TDI
Year of manufacture: 1999.
Translated on 09-10-2026, 0:03.
Madness
Post22-05-2005, 21:37    Subject: Heated Mirrors: A New Approach! Quote
I think your switch might not be disconnecting properly anymore. Have you ever replaced it?
Translated on 09-10-2026, 0:04.
Post23-05-2005, 11:15    Subject: Heated Mirrors: A New Approach! Quote
Madness wrote:
I think that your switch is no longer making contact.
I doubt that, because the driver's side mirror, passenger side mirror, and rear window defroster should all be connected to the same wire behind the switch.
I suspect you have a broken wire, which is causing the driver's side mirror to heat up continuously. A likely culprit would be the wiring harness that runs to the driver's door. Take a look inside there.
Guste.
Translated on 09-10-2026, 0:05.
No new posts Passat 2000: Heated Mirror Not Working? (Troubleshooting) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heated Side Mirrors Diesel Engine Technology
No new posts Exterior mirror glass adhesive Transmission, Chassis, Body & Interior
No new posts Automatic folding exterior mirrors - Installation assista... Diesel Engine Technology
No new posts Retractable Side Mirrors: Touran Aftermarket Installation Transmission, Chassis, Body & Interior
