Engine Idling Low: Troubleshooting & Repair Guide (Solution)
Michael II
Post08-10-2002, 14:51    Subject: Engine Idling Low: Troubleshooting & Repair Guide Quote
1.9L TDI - 81 kW / 66 kW
The engine is running at only 500 RPM after starting and not responding to the accelerator.
Cause:
Due to an excessively short starting process and consequently a low starter motor speed, the engine remains at approximately 500 RPM, which is its idle speed.
Procedure:
The engine can be stopped immediately and then restarted. To prevent repeated occurrences, the starter must be engaged for at least 2 seconds. If the starter is not engaged long enough, the control unit receives incorrect information, which can cause the aforementioned problem.
Tschüss
Michael II
Translated on 27-07-2026, 9:41.
Ratings - Engine Idling Low: Troubleshooting & Repair Guide
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3 8P1, Air conditioning not functioning, no ref... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Engine Won't Accelerate? Troubleshooting Guide. Diesel Engine Technology
No new posts VW AAZ: No Acceleration Below 1/3 Throttle Diesel Engine Technology
No new posts TDI Engine: Won't Accept Fuel? Troubleshooting Diesel Engine Technology
No new posts 1.9 TDI: Intermittent Engine Misfire - Causes & Fixes On-Board Diagnostics (OBD)
