Tuning Box: Reduce Soot & Improve Performance
avoso
Post07-10-2002, 14:21    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
I purchased a so-called 'BlackBoxx' some time ago and installed it in my Audi with an AKN engine. The increase in power was very impressive, but the enormous amount of black smoke was less desirable!
The module was repeatedly sent back and forth until a setting was reached where the increase in performance was minimal, but no or only very little black smoke was visible.
Now, my actual question is:
If I were able to access the engine control unit and set the fuel injection amount to the minimum value within its possible range, would the black smoke disappear? Or would this lead to other undesirable effects, such as excessively high combustion temperatures?
Ziel dieser ganzen Aktion ist max. Mehrleistung (natürlich im möglichen Rahmen) bei min. SBlack smoke!
Best regards, Achim.
Translated on 24-08-2026, 10:44.
Post07-10-2002, 15:01    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
More power equals more black smoke; you can adjust things on the control unit or in the engine management system, but that won't change it.
You have to live with it or increase the boost pressure.
Translated on 24-08-2026, 10:45.
avoso
Post07-10-2002, 18:15    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
Isn't the boost pressure already increased by the tuning box?
If not, how can this be done? I read something about replacing an SMD resistor in the '10Cent Tuning' section. Does this apply to my engine as well? How do I find this resistor?
Translated on 24-08-2026, 10:46.
Post07-10-2002, 19:10    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
Hi.
avoso wrote:
Isn't the boost pressure automatically increased by the tuning box anyway?
Basically, no.
If not, how can this be done? I read something about replacing an SMD resistor in the "10Cent Tuning" section; does this apply to my engine as well? How do I find this resistor?
It depends on where your pressure sensor is located... I don't know if the AKN has an external intake manifold sensor, or if it's integrated into the engine control unit.
Translated on 24-08-2026, 10:47.
avoso
Post07-10-2002, 20:20    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
Hello Ulf,
The sensor definitely has to be located directly on the engine in order to record data locally. Or are the measured values 'converted' by some vehicles before they reach the control unit?
'Does anyone know how much you can increase the boost pressure on a V6 engine without causing any major problems? I've read that it can be increased by up to 0.2 bar – does this also apply to the AKN engine?'
Best regards and thank you for your replies.
Okay, here's the translation:
'Achim'
Translated on 24-08-2026, 10:49.
Post08-10-2002, 12:01    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
avoso wrote:
The sensor definitely has to be located directly on the engine in order to record the data locally! Or are the measured values "recalculated" for some vehicles before they reach the control unit?
Hi.
Yes, certainly, and also not quite: In older TDI engines, the sensor is located in the engine control unit (ECU) and receives the boost pressure from the intake manifold via a pressure hose.
The same principle applies to these types of motors regarding the replacement of resistors.
For sensors located within a pressure pipe, it is possible to use a diode or a resistor in the signal line.
It seems like Georg has some practical experience in that area...
Translated on 24-08-2026, 10:50.
Achim
Post08-10-2002, 12:20    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
@ulf
'Could the boost pressure be adjusted on older models using a hose?'
Control unit, also with a throttle in the measurement hose?
e.g., by increasing from Festo, by...
one can restrict the airflow with a throttle and thus reduce the boost pressure sensed by the engine control unit.
pretends to be something it actually is?
Translated on 24-08-2026, 10:52.
avoso
Post08-10-2002, 14:31    Subject: Tuning Box: Reduce Soot & Improve Performance Quote
Thank you, Ulf!
Finally, I can see the connection!
Translated on 24-08-2026, 10:53.
Post08-10-2002, 15:30    Subject: Throttle Trick: How to Increase Engine Power Quote
Achim wrote:
Could the boost pressure, in older models with a hose to the control unit, not also be regulated using a throttle valve in the measurement hose?
For example, to increase the pressure from Festo, you could restrict the flow by adjusting the throttle, thereby making the control unit believe that there is less intake pressure than actually exists?
Hi Achim,
In principle, that should also work, although I'm not familiar with the necessary hardware for it.
However, the electronic solution is significantly cheaper in terms of materials.
Therefore, this approach is included in the 10c tuning (otherwise, it would probably cost €10 for a boost pressure tuning icon_wink.gif).
Translated on 24-08-2026, 10:54.
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts Momentanverbrauch 1,4TDI unter Vollast Diesel Engine Technology
No new posts Diesel Temperature & Intake Air Temp Under Load Diesel Engine Technology
No new posts Leistung knickt am Berg unter Vollast ein (A3 1,9 TDI- ALH) Diesel Engine Technology
No new posts 2.0 TDI BMM: Power Loss, Soot & DPF Issues Diesel Engine Technology
