Oil level warning light not clearing, MJ 2002 (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post08-10-2002, 15:42    Subject: Oil level warning light not clearing, MJ 2002 Quote
Model year 2002, oil level warning cannot be reset.
Cause:
When the minimum oil level is reached, the oil level warning light in the instrument cluster correctly illuminates. However, it cannot be reset by simply adding more engine oil. While opening and closing the front hood temporarily turns off the warning light for approximately 100 kilometers, it then reappears again, even when the engine oil level is at its maximum. This is due to a software error in the engine control unit.
ASZ engine, 96 kW:
Replace the control unit index CK data version from 1343 to 1477.
Replace the control unit index EF data version 1331 with data version 1478.
ATD engine, 74 kW:
Replace the control unit index FH data version 1517 with data version 1544.
Replace the control unit index GC data version 1462 with data version 1545.
AXR 74 kW engine:
analog ATD motor.
Tschüss
Michael II
Ratings - Oil level warning light not clearing, MJ 2002
No new posts Parking Brake Stuck - Audi A2 8Z0 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2002, Türen lassen sich nicht öffnen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: No Central Locking on Polo 1.4 TDI (2002) On-Board Diagnostics (OBD)
No new posts Control units not responding... Polo 9N AXR 2002 On-Board Diagnostics (OBD)
No new posts Passat TDI 2002: Euro 3 Specs & Info Diesel Engine Technology
No new posts CAN- Verteiler A4 Bj. 2002 On-Board Diagnostics (OBD)
