Replacing the J393 comfort electronics control unit
bille-online
Post05-06-2005, 12:09    Subject: Replacing the J393 comfort electronics control unit Quote
Hello, I'm referring to the following thread because I'm experiencing the exact same problem.
/viewtopic.php?t=1870&highlight=j393
First, I will try to replace the capacitor.
If this doesn't work, I will obtain a replacement part.
My question: Besides pairing the keys, is there anything else I need to be aware of when replacing the device? I bought an interface cable and VAG COM for that.
The engine control unit (ECU) that needs to be located has the part number: 1C0 959 799 B.
Best regards.
bille-online...
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Replacing the control unit On-Board Diagnostics (OBD)
No new posts Replacing the AFN control unit in an Audi A4 On-Board Diagnostics (OBD)
No new posts Replace Airbag Control Unit: Guide & How-To On-Board Diagnostics (OBD)
No new posts Airbag Control Unit: Coding Only? On-Board Diagnostics (OBD)
