TDI Engines: No Blow-Off Valve? Why?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
wuze60
Post08-10-2002, 21:36    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
Hey everyone!
I have a question.
Why don't TDI engines with wastegate turbos have a blow-off valve?
Perhaps a silly question, but is this valve present in gasoline engines?
When the throttle closes in a gasoline engine, the excess pressure is released through the blow-off valve.
I know these don't have a throttle valve, but what happens to the excess pressure that is still temporarily present?
Does it normally enter the combustion chamber and function properly?
Who knows a little bit about this?
Translated on 23-10-2026, 10:06.
Docter
Post09-10-2002, 0:46    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
In a gasoline engine, without a blow-off valve, the turbine wheel is braked by the back pressure from the throttle valve, causing the turbocharger to lose speed and the boost pressure to decrease. The blow-off valve simply redirects the air... to put it simply.
For diesel engines, there is no diesel knock (DK) that slows down the turbocharger.
Translated on 23-10-2026, 10:07.
subman82
Post08-06-2005, 11:34    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
hi!
'Nowadays, there are also these valves available for TDi engines. However, the prices start at around €179 at [company name]. It would be great if there was an instruction manual for doing it yourself, so that you would only need to buy this valve.'
I heard it once and didn't think it was that bad for a diesel.
Translated on 23-10-2026, 10:08.
lappen
Post08-06-2005, 11:49    Subject: SEO-Optimized Title: **"Best SEO Services: Boost Your Rankings Now!"** Quote
hi!
And what does it achieve besides 'TSTSTSTSTS'? Absolutely nothing, not even a single thing, except for emptying your wallet!!!
Search function rocks!
Translated on 23-10-2026, 10:09.
subman82
Post08-06-2005, 11:59    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
Sure, if you look at it that way, you might as well buy a Fiat Panda, it'll still get you there!
Translated on 23-10-2026, 10:10.
lappen
Post08-06-2005, 12:02    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
What do you mean?
subman82
Post08-06-2005, 12:13    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
That's not what's important here! I posted this under this title because it was the first thing I found on the page related to the topic of blow-off valves for TDI engines.
'If you don't want to contribute anything useful, please don't post here! I know this isn't a tuning-specific website, but I've had good experiences with it and received helpful advice. If someone offers a cost-effective solution to my question, I would consider installing that 'TSTSTSTSTS' thing in my car. I wasn't trying to force that on you, and I've never claimed that it's a must-have.'
Translated on 23-10-2026, 10:11.
pschaefer
Post08-06-2005, 12:43    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
now offers a cost-effective solution
What problem are you referring to?
Translated on 23-10-2026, 10:12.
lappen
Post08-06-2005, 12:56    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
That's not what's important right now! I posted this under this title because it was the first thing I found on the page related to the blow-off valve for the TDI.
'If you don't want to contribute anything useful, then don't post anything here! I know this isn't a tuning-specific website, but I've had good experiences with it and received competent help. If someone now offers a cost-effective solution to my question, I would install that 'TSTSTSTSTS' thing in my car. I wasn't trying to force that on you, and I've never claimed that you absolutely need to have it.' https://community.dieselschrauber.org/en/viewtopic.php?t=7587
Here's the translation:
'What problem does this part solve, and is it a cost-effective solution? As I said, this part is useless for a TDI!'
2. Do you know this? }
I think you've gotten yourself into quite a mess!
3. There have already been several discussions regarding the usefulness or lack thereof of these 'blow-offs.' Please search for and read these discussions.
Translated on 23-10-2026, 10:13.
subman82
Post08-06-2005, 12:57    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
Here it is again, for you. It seems this topic isn't letting you rest!
'quote:'
'...a set of instructions for making it yourself, so that you would only need to buy this valve, would be a great thing icon_smile.gif '
The question is whether someone has enough knowledge to list all the necessary parts and perhaps document the process with pictures, so that a novice can install it themselves for a reasonable price.
I didn't want to create such a fuss about it, and I don't understand why so much needs to be written *around* the topic. Or did I make my request for instructions so incomprehensible?
Translated on 23-10-2026, 10:15.
lappen
Post08-06-2005, 13:20    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
And I'm curious about your intention to throw money away. But I don't care, it's your money. And don't say we didn't warn you!
Furthermore, installation instructions can be found on various websites offered by different providers of this type of technology.
Translated on 23-10-2026, 10:16.
subman82
Post08-06-2005, 13:31    Subject: TDI Engines: No Blow-Off Valve? Why? Quote
That's probably my own business. Some people have horses, ride through history, and invest thousands of euros in them – each to their own. I just happen to like putting a loud exhaust system on my car.
'And for that, I was seeking advice. If you had provided the links now, I would have been completely satisfied and wouldn't have had to post here unnecessarily three times.'
'Nevertheless, thank you for trying to protect me from making mistakes.'
Translated on 23-10-2026, 10:17.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Why not a VR6 TDI? Diesel Engine Technology
No new posts How is the vgt valve controlled? Diesel Engine Technology
No new posts vgt-valve operation Diesel Engine Technology
No new posts Why is only 1Z stuttering? Diesel Engine Technology
