Document error 00575 with full throttle, AKN and AFB engine (Solution)
Michael II
Post09-10-2002, 12:02    Subject: Document error 00575 with full throttle, AKN and AFB engine Quote
V6 TDI engine, AKN/AFB type.
When accelerating fully, the engine power is significantly reduced.
Error code 00575 in the engine control unit (ECU) memory.
Cause:
When demanding maximum acceleration, the boost pressure can temporarily exceed the target value. Before the boost pressure control valve can regulate the pressure, the engine control unit (ECU) detects the excessive boost pressure due to the engine protection function and reduces the fuel injection amount. At the same time, the error code 00575 (charge pressure regulation limit exceeded) is stored.
After turning the ignition on/off, the protective function is deactivated, but the error message remains.
Procedure:
In case of a complaint, use a motor control unit with a modified turbocharger pressure sensor.
Tschüss
Michael II
Ratings - Document error 00575 with full throttle, AKN and AFB engine
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation: Performance Issues, Error 17964, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Log: Error at 1800 seconds Upload
No new posts Audi AFB `98: P0113 - Low Intake Manifold Pressure Diesel Engine Technology
No new posts TDI 96kW: Top Speed 130 km/h Diesel Engine Technology
No new posts Performance Issues at Full Throttle Diesel Engine Technology
