Document: Performance Issues, Error 17707, AKF Motor (Solution)
Michael II
Post09-10-2002, 12:41    Subject: Document: Performance Issues, Error 17707, AKF Motor Quote
V8 TDI, 3.3L AKF engine, up to serial number 4D 1N 004 160.
Lack of power, preheating indicator blinking, error code:
Cause:
After startup, the high-pressure pump performs a self-test. If the engine is accelerated rapidly at this moment, the engine control unit (ECU) may detect that the fuel rail pressure is not decreasing quickly enough. The error log then contains the entry: "17707 - Malfunction in fuel metering valve."
Procedure:
If the error occurred during acceleration, the Engine Control Unit (ECU) 1 (Master) must be replaced. The software version of the Engine Control Unit 2 (Slave) must be at least D03. Is this not the case where Motor Control Unit 2 also needs to be replaced?
Tschüss
Michael II
Ratings - Document: Performance Issues, Error 17707, AKF Motor
No new posts Documentation: Performance Issues, Error 17964, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKF, Performance Issues, Error 17964 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKF Motor: Performance Issues & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idle High: 1250 RPM, Low Power, 6 Errors On-Board Diagnostics (OBD)
No new posts Power shortage in ARL engine Diesel Engine Technology
No new posts Leistungsmangel A4 Motor AKN On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Audi A6 Engine Problems: Lack of Power? Diesel Engine Technology
