AKF Motor: Performance Issues & Troubleshooting (Solution)
Michael II
Post09-10-2002, 12:50    Subject: AKF Motor: Performance Issues & Troubleshooting Quote
3.3 liters, 8-cylinder TDI, AKF engine, up to serial number 4D 2N 001 542.
Lack of power, sudden power loss, the vehicle occasionally has no power, error code 17964 (boost pressure control limit exceeded).
Cause:
It is possible for the vacuum lines to tear, especially the angled connectors for the magnetic valves of the turbocharger pressure control system. Depending on the location and position of the lines, leaks and error messages may occur sporadically.
Procedure:
For error code 17964 (boost pressure control, lower limit exceeded), check for any leaks in the vacuum hoses. Pay particular attention to the angled connectors in the vacuum hose system. A vacuum pump can be used to apply vacuum to the hoses and check for leaks.
"Note: "
If error code 17567 (Signal from mass airflow sensor 1/mass airflow sensor 2: implausible ratio) is also stored in the fault memory, this is a consequential error related to a vacuum leak in the charge pressure control system. The mass airflow sensor should not be replaced in this case!
Tschüss
Michael II
Translated on 13-09-2026, 23:40.
Ratings - AKF Motor: Performance Issues & Troubleshooting
Average rating: 2.00 - worst rating: 2 - best rating: 2 - number of ratings: 1 - View ratings
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation: Performance Issues, Error 17964, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsmangel A4 Motor AKN On-Board Diagnostics (OBD)
No new posts Power shortage in ARL engine Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A6 Engine Problems: Lack of Power? Diesel Engine Technology
No new posts AEL Engine: Low Power, High Fuel Consumption On-Board Diagnostics (OBD)
