Knaller 2/3 für 2005... | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post16-02-2005, 17:36    Subject: Quote
Hi Alex,
Currently, KPower is a standalone program. It is likely that it will continue to allow for simple log file import in the future, without necessarily having to run as a plugin.
KPower, as a VAG-COM plugin, would have the advantage that the user would only need to press a "start measurement" button, and the program would automatically handle everything else (selecting measurement blocks, providing instructions to the driver). The intermediate step of saving and potentially editing a log file would then be eliminated.
Currently, it works like this:
- 3rd or 4th gear, with a rolling speed of 1500 RPM.
- Start logging of measurement block 5 (or the block that contains speed and RPM data).
- Full throttle to the maximum RPM.
- Depress the clutch and let the car roll to a stop.
- Stop logging.
- Import log from KPower.
- Adjust vehicle data.
- Check the performance curve.
If the weather is good, I might try logging some data myself. So far, I've only used pre-existing log files because of the snow and other weather conditions.
Translated on 26-08-2026, 18:33.
Post17-02-2005, 21:48    Subject: Translating...
[Translating...]
dakoal
Post12-06-2005, 18:06    Subject: Import Excel Data: Easy & Fast Guide Quote
Now that I have a semi-professional diagnostic system, I also have access to the K-Power tool.
Here's my initial contribution:
My control unit is too slow to log MWBlock 005 and 006 simultaneously.
"So, I only log the 006 (which represents km/h), and then I manually add the RPM value to the corresponding row using a formula."
All of this is done using Excel.
I can then easily copy and paste the values into the spreadsheet.
Unfortunately, that doesn't work with K-Power.
I'll test it today with version 3.0.4 (I'm not sure which version came with the Semiprof diagnostic tool).
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 26-08-2026, 18:36.
Back to top Profile PM Email
Post12-06-2005, 18:36    Subject: Quote
Copying and pasting should also work... version 3.0.4 is currently included in all systems.
[Edit: As of January 1, 2006: the current version is 3.0.6]
Translated on 26-08-2026, 18:37.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Knaller 1/3 für 2005... On-Board Diagnostics (OBD)
No new posts Knaller 3/3 für 2005... On-Board Diagnostics (OBD)
No new posts VAG-COM Deals 2006: Best Offers & Savings On-Board Diagnostics (OBD)
No new posts Altea 2.0 FSI: Specs & Info for 2005 Model Gasoline Engine Technology
