Boost Pressure Problems: N75 & Manifold Pressure Sensor
estekay
Post10-10-2002, 10:12    Subject: Boost Pressure Problems: N75 & Manifold Pressure Sensor Quote
Question for the experts:
Can a faulty wastegate control valve (N75) affect the intake manifold pressure sensor (G71 - is this actually located in the engine control unit for the 1Z engine?) to the extent that an error code 00519 (short circuit to positive - intermittent) occurs?
Basically:
Why do N75 valves fail? I've noticed on my Passat (which has been modified with silicone hoses for the small pressure lines) that small amounts of oil are leaking from the crankcase ventilation system to the N75 valve and the EDC. This can only be harmful, especially if there are rubber seals inside. Has anyone found a workaround for this problem?
Best regards, Steffen.
Translated on 29-08-2026, 23:48.
No new posts Problems with the intake manifold pressure sensor on the AFN On-Board Diagnostics (OBD)
No new posts VNT15 AFN: Common Problems and Solutions Diesel Engine Technology
No new posts L200 Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
No new posts Boost Pressure Limiter: Explained & Benefits On-Board Diagnostics (OBD)
