Air Mass Sensor: Buy Online & Save!
Hugo001
Post18-06-2005, 7:09    Subject: Air Mass Sensor: Buy Online & Save! Quote
Hello, I have a problem. I was at a friend's place, and he said that my Passat doesn't have enough power for a 1.9 TDI with 115 horsepower.
We then replaced the mass airflow sensor with a new one, and lo and behold, the car runs great. javascript:emoticon('icon_biggrin.gif')
Very Happy: After starting it twice, I had the usual performance again.
We then swapped two more parts, and they are both located on the rear side of the engine.
Everything without success. javascript:emoticon('icon_cry.gif')
Crying or very sad.
He now wants to replace the part connected to the mass airflow sensor and the part located behind the radiator. What else can be done?
Translated on 22-09-2026, 5:35.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post18-06-2005, 7:38    Subject: Air Mass Sensor: Buy Online & Save! Quote
I don't think anyone can really help you with that description.
Translated on 22-09-2026, 5:36.
Post18-06-2005, 12:06    Subject: Air Mass Sensor: Buy Online & Save! Quote
It's not going to work like this.
1. Read the error memory to check if the emergency program was activated.
2. Compare the actual and target values for LMM; the actual value must always be higher than the target value.
Translated on 22-09-2026, 5:37.
Hugo001
Post20-06-2005, 3:01    Subject: Air Mass Sensor: Buy Online & Save! Quote
17964 - Charge pressure regulation: Limit exceeded.
P1556 - 35-00 - -
wolfi_b
Post20-06-2005, 6:36    Subject: Air Mass Sensor: Buy Online & Save! Quote
Have you tried using the search function yet?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
syncro peter
Post20-06-2005, 7:44    Subject: Air Mass Sensor: Buy Online & Save! Quote
Even if you only enter '17964', you will be overwhelmed with results.
I am a nice guy, you know icon_twisted.gif.
Error code: 17964.
Boost pressure regulation: Limit exceeded.
Possible causes:
Faulty turbocharger wastegate control valve (N75), leaky hose connections.
Turbocharger failure.
Air leak between the turbocharger and the engine (charge air path).
Possible impacts:
reduced performance.
Low boost pressure.
Translated on 22-09-2026, 5:38.
hb2000
Post20-06-2005, 10:36    Subject: Air Mass Sensor: Buy Online & Save! Quote
A boost pressure gauge can be incredibly helpful in this situation. Otherwise, first check the entire charge air system for leaks, and then continue troubleshooting.
Translated on 22-09-2026, 5:39.
Hugo001
Post21-06-2005, 6:56    Subject: Air Mass Sensor: Buy Online & Save! Quote
Okay, thank you.
Translated on 22-09-2026, 5:40.
hb2000
Post21-06-2005, 13:29    Subject: Air Mass Sensor: Buy Online & Save! Quote
and the search function is absolutely great in this forum -> it's really worth using icon_biggrin.gif.
No new posts Air Mass Sensor: Readings for Gasoline Engines General Tips
No new posts Air Mass Sensor: Expensive Weakness in VW/Audi TDI Technical Articles
No new posts 16488/P0104/000260 - Mass Air Flow Sensor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Mass Sensor: The Story Behind It Diesel Engine Technology
No new posts Air Mass Sensor Calibration Circuit Diesel Engine Technology
No new posts Mass air flow sensor from eBay? Diesel Engine Technology
No new posts Air Mass Meter Audi 90 20v Diesel Engine Technology
