Manifold pressure signal influence
Dieselmike
Post23-06-2005, 12:17    Subject: Manifold pressure signal influence Quote
Hello.
I'm currently in the process of installing a boost controller in my car. In the instructions, I noticed that it's not currently possible to influence the boost pressure with systems like AHF because you don't know the signal from the intake manifold pressure sensors. Has anyone already done any research on this? Otherwise, I'll try experimenting and see how to manipulate the signal. I suspect it will be similar to how it works with an AFN engine. To do this, I need to set up a measurement circuit to determine whether the pressure is converted into a voltage or current signal.
Best regards, Mike.
Translated on 23-08-2026, 20:13.
Dieselmike
Post23-06-2005, 21:45    Subject: Manifold pressure signal influence Quote
Hello fellow diesel enthusiasts!
Thank you for your patient silence; I've already found a starting point myself. /viewtopic.php?t=6874&highlight=ladedruckerh%F6hung+beim+afn
While I believe a diode offers one possible solution, it's quite a crude method. It can lead to overshooting in the control loop and cause voltage spikes. I'll see what else can be done.
Hi Mike,
Translated on 23-08-2026, 20:14.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts V6 TDI Intake Manifold Pressure Diesel Engine Technology
No new posts Intake Manifold Pressure Regulation Difference Upload
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
