Driver's desired setting too low?
pschaefer
Post26-06-2005, 15:10    Subject: Driver's desired setting too low? Quote
Hello!
I borrowed another Pierburg mass airflow sensor and logged the results (see the Excel or OpenOffice file). The Excel file was also created using OOO, and I cannot guarantee its accuracy (I don't have Windows here).
The values that the LMM (likely referring to a mass airflow meter) is providing are terrible, that's clear. But what I've noticed is that my desired airflow reading rarely exceeds 60, while according to the specification table, it should be 65-70 - which is also what I've seen in other logs here (they're usually around 69). Could this be due to the automatic transmission? The Drehmo limit seems to be "normal" again...
By the way: The value for the smoke limit in the target data table is incorrect, but Roger has already noticed that.
Peter.
Post27-06-2005, 6:17    Subject: Re: Driver's seat too low? Quote
pschaefer wrote:
My desired driving mode rarely exceeds 60, while the target data table indicates it should be 65-70 - which is also what can be seen in other logs here (they are usually around 69). Could this be due to the automatic transmission? The Drehmo limit appears to be "normal" again...
"Special drives" can sometimes cause certain vehicle components to behave differently than usual.
Call a tow truck and have them bring a vehicle with a manual transmission. If it reaches 100% when running at full speed, it's most likely okay.
Which MSG (Message Security Gateway) did you install? (The last two letters are important.)
Post27-06-2005, 6:56    Subject: Driver's desired setting too low? Quote
In the log file, it shows that the accelerator pedal reached 100% multiple times.
The engine control unit is a 038 906 019 HJ - this is also indicated in the log icon_smile.gif.
Post27-06-2005, 7:17    Subject: Driver's desired setting too low? Quote
dieselmartin wrote:
In the log file, he repeatedly reached 100% accelerator/pedal.
The engine control unit is a 038 906 019 HJ - this is also shown in the log icon_smile.gif
Hmm, the links aren't working for me...
pschaefer
Post27-06-2005, 10:40    Subject: Driver's desired setting too low? Quote
Hm, the links didn't open for me.
It shouldn't be. What kind of error message did you get? A 404?
With "special drives," some vehicles may behave differently than usual.
Call a tow truck and have them bring a vehicle with a manual transmission. If it reaches 100% when running at full throttle, it is most likely that everything is OK.
Okay, then everything is fine.
Thank you!
No new posts Low rail pressure, 3.0 CR-TDI General Tips
No new posts Fuel pressure too low (P0087) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2303 - Ignition Coil B, Primary Circuit: Signal too low Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LD Control Log via Driver Request (LMM Off) Upload
No new posts Low Smoke Suppression: Causes & Solutions On-Board Diagnostics (OBD)
No new posts C2 catalyst conversion rate too low Gasoline Engine Technology
No new posts Low Control Unit Voltage: Troubleshooting Guide On-Board Diagnostics (OBD)
