Passat B5, 85 kW, engine code: ATJ.
Mounting nut, tensioner roller.
Affected vehicle identification numbers:
WVW ZZZ 3BZ YE 261,000 to WVW ZZZ 3BZ YE 999,999.
WVW ZZZ 3BZ YP 221,500 to WVW ZZZ 3BZ YP 500,000.
Cause:
For Passat vehicles with an 85 kW TDI engine (engine code: ATJ), there is a possibility that the tensioner mounting nut may come loose.
Procedure:
For all affected vehicles, the tensioner mounting nut needs to be tightened.
Active customer outreach is not performed. Tschüss
Michael II
Translated on 01-09-2026, 6:52.
